I tried to compile arducopter and I got an error related to uavcan apparently.
[14/15] CMake Build px4 msg_gen
No such file or directory
CMake Error: Generator: execution of make failed. Make command was: “” “msg_gen”Compiler failure
Traceback (most recent call last):
File “/home/michiel/ardupilot/modules/uavcan/libuavcan/dsdl_compiler/libuavcan_dsdl_compiler/init.py”, line 300, in enum_last_value
last = next(it)
StopIterationThe above exception was the direct cause of the following exception:
File “/home/michiel/ardupilot/modules/uavcan/libuavcan/dsdl_compiler/libuavcan_dsdl_compiler/init.py”, line 107, in run_generator
text = generate_one_type(template_expander, t)
File “/home/michiel/ardupilot/modules/uavcan/libuavcan/dsdl_compiler/libuavcan_dsdl_compiler/init.py”, line 239, in generate_one_type
text = template_expander(t=t) # t for Type
File “/home/michiel/ardupilot/modules/uavcan/libuavcan/dsdl_compiler/libuavcan_dsdl_compiler/init.py”, line 307, in expand
return template(**args)
File “/home/michiel/ardupilot/modules/uavcan/libuavcan/dsdl_compiler/libuavcan_dsdl_compiler/pyratemp.py”, line 1030, in call
u = “”.join(self._render(self.parsetree, self.current_data))
File “/home/michiel/ardupilot/modules/uavcan/libuavcan/dsdl_compiler/libuavcan_dsdl_compiler/pyratemp.py”, line 1130, in render
output.extend(self.render(elem[2], data))
File “/home/michiel/ardupilot/modules/uavcan/libuavcan/dsdl_compiler/libuavcan_dsdl_compiler/pyratemp.py”, line 1104, in render
output.append(unicode(_eval(elem[1], data)))
File “/home/michiel/ardupilot/modules/uavcan/libuavcan/dsdl_compiler/libuavcan_dsdl_compiler/pyratemp.py”, line 1079, in _eval
return self.evalfunc(expr, data)
File “/home/michiel/ardupilot/modules/uavcan/libuavcan/dsdl_compiler/libuavcan_dsdl_compiler/pyratemp.py”, line 884, in eval
x = eval(self.compile(expr), {“builtins”:self.eval_allowed_globals}, locals)
File “”, line 1, in
File “”, line 1, in
File “/home/michiel/ardupilot/modules/uavcan/libuavcan/dsdl_compiler/libuavcan_dsdl_compiler/pyratemp.py”, line 1138, in render
output.extend(self.render(elem[1], data))
File “/home/michiel/ardupilot/modules/uavcan/libuavcan/dsdl_compiler/libuavcan_dsdl_compiler/pyratemp.py”, line 1119, in render
for i in loop_iter:
RuntimeError: generator raised StopIterationDuring handling of the above exception, another exception occurred:
File “/home/michiel/ardupilot/modules/uavcan/libuavcan/dsdl_compiler/libuavcan_dsdlc”, line 61, in
dsdlc_run(args.source_dir, args.incdir, args.outdir)
File “/home/michiel/ardupilot/modules/uavcan/libuavcan/dsdl_compiler/libuavcan_dsdl_compiler/init.py”, line 62, in run
run_generator(types, output_dir)
File “/home/michiel/ardupilot/modules/uavcan/libuavcan/dsdl_compiler/libuavcan_dsdl_compiler/init.py”, line 111, in run_generator
die(ex)
File “/home/michiel/ardupilot/modules/uavcan/libuavcan/dsdl_compiler/libuavcan_dsdl_compiler/init.py”, line 89, in die
raise DsdlCompilerException(str(text))
libuavcan_dsdl_compiler.DsdlCompilerException: generator raised StopIteration
uavcangen returned 1 error code
I am running arch linux, uavcan is installed in both pip2 and pip3. (The error occured before I installed those as well).
Anyone got any tips for me?
Thanks in advance,
Michiel
