I’m trying to build the firmware, without success. I’m running in an Ubuntu 18.04 docker image. I tried the following steps:
yes | Tools/environment_install/install-prereqs-ubuntu.sh
# open new terminal
./waf configure --board PH4-mini
./waf copter
This fails after a while with these errors:
[ 11/685] Compiling libraries/AC_AttitudeControl/AC_AttitudeControl_Sub.cpp
[ 12/685] Compiling libraries/AC_AttitudeControl/AC_AttitudeControl_Heli.cpp
[ 13/685] Compiling libraries/AC_AttitudeControl/ControlMonitor.cpp
[ 14/685] Compiling libraries/AC_AttitudeControl/AC_AttitudeControl_Multi.cpp
[ 15/685] Compiling libraries/AC_AttitudeControl/AC_PosControl_Sub.cpp
[ 16/685] Compiling libraries/AC_AutoTune/AC_AutoTune.cpp
g++: warning: '-mcpu=' is deprecated; use '-mtune=' or '-march=' instead
g++: error: nano.specs: No such file or directory
Waf: Leaving directory `/home/alex/workspaces/4/git/ardupilot/build/PH4-mini'
Build failed
-> task in 'objs/AC_AttitudeControl' failed (exit status 1):
{task 140472954406480: cxx AC_AttitudeControl_Sub.cpp -> AC_AttitudeControl_Sub.cpp.0.o}
(run with -v to display more information)
{task 140472954406224: cxx AC_AttitudeControl_Heli.cpp -> AC_AttitudeControl_Heli.cpp.0.o}
{task 140472954406736: cxx ControlMonitor.cpp -> ControlMonitor.cpp.0.o}
{task 140472954406352: cxx AC_AttitudeControl_Multi.cpp -> AC_AttitudeControl_Multi.cpp.0.o}
{task 140472954406608: cxx AC_PosControl_Sub.cpp -> AC_PosControl_Sub.cpp.0.o}
Running ./waf copter -v reveals that it is running /usr/bin/g++ instead of the arm-none-eabi-g++ toolchain that we specifically installed. This seems like a poor choice.
I read modules/waf/waflib/Tools/compiler_cxx.py and decided to try CXX=arm-none-eabi-g++ ./waf configure --board=PH4-mini before running ./waf copter -v. This resulted in different build errors, a bunch of these:
cc1plus: error: -Werror=implicit-fallthrough: no option -Wimplicit-fallthrough
cc1plus: warning: unrecognized command line option '-Wno-expansion-to-defined'
Again this makes a bit of sense as these options don’t exist in GCC 6, so passing them seems like a poor choice.
So I seem to be stuck. I can force waf to use the correct compiler using this undocumented option, but that compiler is too old for the options being passed. What am I missing here?
$ ./waf configure --board=PH4-mini
Setting top to : /home/alex/workspaces/0/git/ardupilot
Setting out to : /home/alex/workspaces/0/git/ardupilot/build
Autoconfiguration : enabled
Setting board to : PH4-mini
Using toolchain : arm-none-eabi
Checking for 'g++' (C++ compiler) : /usr/bin/g++
Checking for 'gcc' (C compiler) : /usr/bin/gcc
Checking for c flags '-MMD' : yes
Checking for cxx flags '-MMD' : yes
Checking for program 'make' : /usr/bin/make
Checking for program 'arm-none-eabi-objcopy' : /opt/gcc-arm-none-eabi-6-2017-q2-update/bin/arm-none-eabi-objcopy
Including /home/alex/workspaces/0/git/ardupilot/libraries/AP_HAL_ChibiOS/hwdef/fmuv5/hwdef.dat
Adding environment OPTIMIZE -O2
Removing IOMCU_UART
Removing UART8_TX
Removing UART8_RX
Removing AP_FEATURE_SBUS_OUT
Removing PA5
Removing PB3
Removing PB11
Removing FMU_CAP1
Removing FMU_CAP2
Removing FMU_CAP3
Removing HAL_BATT_VOLT_SCALE
Removing HAL_BATT_CURR_SCALE
Setup for MCU STM32F767xx
Writing hwdef setup in /home/alex/workspaces/0/git/ardupilot/build/PH4-mini/hwdef.h
MCU Flags: cortex-m7 ['-mcpu=cortex-m7', '-mfpu=fpv5-d16', '-mfloat-abi=hard']
Writing DMA map
Generating ldscript.ld
Default parameters path from hwdef: /home/alex/workspaces/0/git/ardupilot/libraries/AP_HAL_ChibiOS/hwdef/PH4-mini/defaults.parm
Checking for env.py
env set DEFAULT_PARAMETERS=/home/alex/workspaces/0/git/ardupilot/libraries/AP_HAL_ChibiOS/hwdef/PH4-mini/defaults.parm
env set BOARD_FLASH_SIZE=2048
env set APJ_BOARD_TYPE=STM32F767xx
env set OPTIMIZE=-O2
env set USBID=0x1209/0x5740
env set MAIN_STACK=0x400
env set APJ_BOARD_ID=50
env set HAL_WITH_UAVCAN=1
env set CORTEX=cortex-m7
env set FLASH_RESERVE_START_KB=32
env set CHIBIOS_BUILD_FLAGS=USE_FATFS=yes MCU=cortex-m7 ENV_UDEFS=-DCHPRINTF_USE_FLOAT=1 CHIBIOS_PLATFORM_MK=os/hal/ports/STM32/STM32F7xx/platform.mk CHIBIOS_STARTUP_MK=os/common/startup/ARMCMx/compilers/GCC/mk/startup_stm32f7xx.mk
env set IOMCU_FW=0
env set CPU_FLAGS=['-mcpu=cortex-m7', '-mfpu=fpv5-d16', '-mfloat-abi=hard', '-DARM_MATH_CM7', '-u_printf_float']
env set PERIPH_FW=0
env set PROCESS_STACK=0x2000
Enabling ChibiOS asserts : no
Checking for intelhex module: : OK
Checking for HAVE_CMATH_ISFINITE : no
Checking for HAVE_CMATH_ISINF : no
Checking for HAVE_CMATH_ISNAN : no
Checking for NEED_CMATH_ISFINITE_STD_NAMESPACE : no
Checking for NEED_CMATH_ISINF_STD_NAMESPACE : no
Checking for NEED_CMATH_ISNAN_STD_NAMESPACE : no
Checking for header endian.h : not found
Checking for header byteswap.h : not found
Checking for HAVE_MEMRCHR : no
Checking for program 'python' : /usr/bin/python
Checking for python version >= 2.7.0 : 2.7.17
Source is git repository : yes
Update submodules : yes
Checking for program 'git' : /home/linuxbrew/.linuxbrew/bin/git
Gtest : STM32 boards currently don't support compiling gtest
Checking for program 'arm-none-eabi-size' : /opt/gcc-arm-none-eabi-6-2017-q2-update/bin/arm-none-eabi-size
Benchmarks : disabled
Unit tests : disabled
Scripting : enabled
Scripting runtime checks : enabled
Checking for program 'rsync' : /usr/bin/rsync
'configure' finished successfully (0.347s)
