Bug Reports and Support
If that doesnt help you can do this:
  1. Go to ArduPilot firmware : /Copter/stable , open your board’s folder (the same board name as in my screenshot) and download arducopter.apj, the one WITHOUT “heli” in the name or path.
  2. In ArduDeck’s firmware screen, flash it as a local file.
  3. Reset all parameters: search FORMAT_VERSION, set it to 0, Save All Changes, then unplug and replug USB. This clears the heli defaults; you’ll redo the accelerometer, compass and radio calibrations afterwards.
  4. Set FRAME_CLASS = 1 and FRAME_TYPE = 1, save, reboot. The header should now say Quadrotor.
I will make this process seamless for the next release.
@GaGaBrisbasne did it work ?
Still won’t do it
I need to get it out of a tree before I can try again. Thanks for the help.
Once it is on the ground again I will try the update again.
Ohh how well i understand you :slight_smile: Prototypes - they like to get in to trees , houses and ground :slight_smile:
