Brushed-with-relay issue
Attached is a folder that contains my params file, a video describing the problem, and some of the key info and wiring diagrams. Any help would be greatly appreciated.
Thanks,
James
your calibration looks off.
the IMU should show level but is showing around 80 degree bank in your video.
Not sure if this might fix the moving issue but a proper calibration of the sensors is very important
also check if your rc signals (from the controller) are working as expected in the setup → rc calibration screen.
It’s a bit difficult to see what’s happening from the video, can you post a text description of the issue and a bin log (from the SD card of the flight controller)?
Hey, I have solved this issue (honestly I don’t know how) but I have run into another. I will post that as a new topic. This particular issue is resolved.
