Bluetooth on Telem1?
I can’t seem to get my pixracer (3DR) to connect to my ground station with a blue tooth module. Can someone point me in the right direction to set up both on the controller side and with a ground station pls? Thx
Why bother, use a WiFi radio.
I have a wifi module too. I’m gonna try that tomorrow. But my iPhone sees and connects to the Bluetooth it’s just neither of my two ground stations see it.
iphones dont support normal classic bluetooth serial, only BLE adapters.
Not that I would use one as I like WiFi radios but an HM-10 module would work? Nice to see the venerable PixRacer is still getting use! I had a bunch of those.
Thing is in my application I need my iPad connected to a wifi device but I also need it to connect to a ground station simultaneously. BTW I think I figured out the reason my blue tooth wasn’t being seen my my Mac is it’s a bit old and the newer ones use a different protocol. I ordered a new one from sparkfun. :+1: yea I started way back with the APM. Then a couple pixrhawks. . Then a couple pix racer. I see the ‘plane’ firmware I have on it is 4.0.6 so that gives you an idea how long it’s been. Family life will do that :wink: I saw the info when I connected direct from usb.
Yea I also tried a BLE module same thing only thing that sees it is their little app. My Mac and iPhone don’t see it.
Here’s where I’m at with my problem. when I said it worked with QGC that’s only directly from then USB cable. I have now tried both blue tooth module and a wifi module. The blue tooth can be seen with an app tool but my Mac arm device [ iPhone or iPad] never sees it. I thought I had it figured out that my blue tooth module wasn’t compatible with BLE so I bought another one. Same problem. So next I tried a little wifi module. I get that connected and my devices and Mac see and connects to the edify but QGC never gets any data. I checked the params [ while connected via USB] that serial 1 is set to ‘2’. as I read it should be. I also created a new network link in GCS as UDP 14550. I recall it used to connect to that right away. [ I sort of stepped away from this hobby several years ago got busy with family etc so it’s been awhile since I used to monkey with this stuff] but now it just never allows the data stream to get to QGC. Next thought is baud rate?? There was ZERO documentation with this little wifi module so I’m not even sure what baud rate it shipped with. But I connected with the usb and tired a couple different frequencies but got tied up and haven’t tried them all. If it’s 115200 do I enter all those numbers in the params or just 11?? Reason I ask is it had just 57 not 5760 so I’m not sure what i should do there do you know?? BTW the wifi module is powered up. I see the light flashing. My Mac is connected to the wifi it’s just no data stream. I have also switched the TX and RX to see if I have those backwards. I remember that can mess you up bc sometimes it says what the component side is and other times it says what you should connect to so you can get that wrong. So at this point I’m thinking I just need to keep playing around with the baud rate via usb [ then reboot the controller]. Obviously this isn’t like a hang grenade ..close isn’t gonna work. lol anyway that’d where I’m at if anyone have some inclination as to what baud rate a stock little Amazon 8 pin wifi module baud rate is or any other suggestions I’d appreciate it!!
What WiFi module? I use the ESP8266 ESP-01 modules but you need to flash Firmware to them.
Yes that’s what I have. I didn’t know they needed flashed!! :roll_eyes: I’m not even sure how to do that sadly. I looked into that for something else not long ago, I successfully installed HomeBrew via terminal on my Mac. After that I have no idea. I remember thinking how do I get terminal to navigate to the file. I don’t see anything like ‘load from file’ or anything similar in menu items. I’ll read over the link you included above. Thanks
actually via that link you send some of them come pre-flashed but I doubt my Amazon china one is.
No, of course not, Those modules have many uses. Get an FTDI adapter and follow the docs to flash it.
I figured it out lol probably a much better one anyway. I originally was looking at BT but this will work I’ll get a dedicated iPad for QGC WiFi Module ESP8266 | Reliable UAV and IoT Connectivity with ArduPilot Firmware
You figured out how to spend a lot of money for a cheap radio but that will do the job.
Just a heads up, but there isn’t a current official version (updated) of QGC for the ipad. (or at least there wasn’t last time I looked a couple of months ago and hasn’t been for some time before that) There is an unofficial version that’s several versions out of date. It works… okay enough.
