Blitz H743 wing
Hello, @tridge
I have blitz h743 wing flight controller. Today i wired everything but Vi1 video input doesnt work. Vi2 works. That’s something you can fix about firmware? or hardware related problem? so can you take action please?
Regards.
EDIT:
Appears this is an open issue. VTX input switching must be done via GPIO pins that do not appear to be exposed to the user as solder pads.
Until this is resolved, Vi2 is the only input that will function properly.
thanks for replying.
its not that GPIOs need to be exposed as pads, the hwdef needs to setup the switch…fixing the Pro will fix his WING since its based off the Pro…
Sorry if I was unclear. If the pins were exposed, there’d be an alternate solution that doesn’t necessitate a firmware change.
hello,
this problem solved?
regards.
