Blheli_s motor crunch sound bug?
Two of my blheli_s vtols motors make crunching knock sound during fixed wing flight. I can also hear it in manual modenspinning the motors on the bench. Im using bdshot dshot300. Happened on beta 2 and beta 4. Any ideas what’s causing this? It doesn’t happen on 4.5.7
Try DSHOT600, maybe that will help. There could be some guidance in this video.
I’m not aware of what would be different between firmware versions that could be causing your issue.
I have try dshot dshot300. And 600 Its onky happening in the beta version of 4.6
Try Bluejay instead, I’m flying a ZOHD Drift with a DYS XSD7A flashed with Bluejay and DSHOT600+EDT with Plane 4.6-beta4.
Im using bluejay. Its still happening. On two different tilt rotor vtols
OK, then hit the discussion for ap46b4, I believe that was the last post.
Since I don’t see it, it may be related to Q-Plane only.
