Big issue with APM 2.6 / calibrating compass
Dear community.
2 months ago, I bought my first apm 2.6.
After waiting some delivery time, I recieved it 2 weeks ago.
I bought the ArduPilot Mega 2.6 with the external compass.
After building my hexdacopter, I mounted all apm hardware.
I succesfull connected it, I have both link (USB and telemetry) working properly.
Now my big problem. After „live calibration“ of the compass, I always get the message „Log does not contain enough data ».
No problem I though, ask Google.
It looks like this is a well known problem.
But.
I really tried everything.
I have no more ideas how to solve that problem.
Thats what I already tried:
  • reconnect all plugs.
  • initialize all ESC again
  • watched nearly all youtube vids how to calibrate a copter,
    tried it at least 30 times in all methods
  • reset the APM
  • changed place where I calibrate it
  • always used Rotation_Roll_180 and choosed external compass
  • simulated a flight with at least 30% throttle (armed the copter manually, drove with car
    while simulting a flight. Don’t ask how this looked like….)
  • after that, I tried to load the datas, same error message….
  • Reinstalled mission planer and the copter software.
Fact is:
  • Compass is working (USB and telemetry link)
  • GPS signal is found (blue LED is constantly bright)
  • Telemetry downlink works
There are people saying, that sometimes the Voltage regulator could get killed…
But all my sensors are working.
I really appreciate if somebody has another solution fort his problem.
I waited over a month to get that ardu and now I can’t use it…
Many thanks!
Pascal
@Pascal,
The heading in the HUD can change direction even if the compass is not working because the APM will use the Az gyro to obtain heading information.
Only rarely have I had a working compass fail the calibration test for not enough data and then a recalibration solved the problem. If repeated calibration attempts result in a not enough data messages, then there is the possibility that the compass is either defective or there is a communication problem between the compass and the APM.
I assume that you have installed the GPS/Compass module per these instructions: copter.ardupilot.com/wiki/common … ss-module/
If your installation appears to be correct, then I suggest that you use the CLI in the Terminal Tab to troubleshoot your problem: copter.ardupilot.com/wiki/using- … apmcopter/
Following the Wiki instructions you can select the “test” function in the CLI and test the compass. If the compass is not functional you will get a message saying that the compass cannot be initialized.
Regards,
TCIII Admin
Many thanks. I’ll try this at home!
I’ll let you know.
regards
Pascal
OK, seems my UBLOX has a problem…
results in CLI:
Compass
enabled
Mag Dec: 0.0000
Mag off: 0.0000, 0.0000, 0.0000
Motor comp: off
test compass:
Compass initialisation failed
hmmmm. send back to 3drobotics?
If you need to send it back contact help@3drobotics.com
Before you do, check that the 4pin i2c cable is properly connected, and none of the pins are bent on the APM2.6 or the connection on the GPS/Compass module.
@billbonney.
I will. The small connectors a a little crappy to remove. But I tried so many things, so this want be a problem anymore. :wink:
thx for your answer.
For information on how to correctly place/remove the connectors, please check this video:
[youtube]https://www.youtube.com/watch?v=zhuV9vDwOs4[/youtube]
Just for your info.
After recieving a replacement (thanks to 3dRobotics), the calibration was ended successful!
Maybe it’s a new software, but this time I can see how many datas the apm is recieving during calibration process.
I didn’t had that on the old / damaged one…
