I am designing and 3d printing a bicopter frame, it’s nearly finished, so the mean time I am having a look at the software side.
Every time I am uploading the copter firmware, I tried 4.1.2 and 3.6.12 and switch the FRAME_CLASS to 10, servo 1 to 4 are configured automatically to the correct settings but I am loosing the extended tuning menu and I can’t select any flight mode, either under action or under setup / flight modes. I tested it with a cubeblack, pixracer and pixhawk 4 mini, same results.
Is there any way to make it work with the copter firmware or should I use plane firmware with Q enabled?
