Beta 3 possible bug
F405 wing. Airspeed auto cal didnt save. Also enable airspeed calibration via switch and disable airspeed use switch does not work too.
Auto cal may not save if the existing value is close. Do you mean the RCx_OPTION values “91:Airspeed Ratio Calibration” and “106:Disable Airspeed Use”? Please share a log of the test.
Yes those two do not work. Or were they removed from the f405 builds?
They should work, I need the .bin log to try and work out why they did not.
As far as I can tell they are both working correctly. For use we can check the use value in the airspeed log against RC 13.
We don’t log if airspeed calibration is active or not.If there is a change in value of more than 5% we do print a message, which we don’t see in this log, but there is no flying either.
What maybe confusing you is that we don’t include the aux function strings on low flash boards such as the MATEK F405’s. On other boards you might be used to seeing “RC13: Calibrate Airspeed HIGH” for example. The functions do all still work, just there are no messages.
Oh so f405 won’t have any mavlink messages or osd messages. Even when airspeed is disabled? I always use h743 based flight controller or cubes. I have used a f405 based FC once before. That did show mavlink messages back in 4.5.X
