Using SF11/C , I usually tell the down looking LIDAR it’s offsets from the Cube,
RNGFND1_POS_Y,0.18
RNGFND1_POS_Z,0.17
And it’s elevation above the ground at that position (due to landing gear height)
RNGFND1_GNDCLEAR,48
This means the copter, when landed, sees a altitude of 48cm.
Is this the best way? , what if I configured a offset rigt in the SF11/C , som that it reported 0cm distance to ground when landed, and had _GNDCLEAR=0?
At least, it would give the copter a little less precise absolute precision, is there an upside of doing this one way or another ?
