Benewake TFS20-L Lidar support
Is anyone using this Lidar, or would it be difficult to integrate? It appears to be the best low cost module in their lineup for outdoor use in bright light, with moderate range suitable for precision landings. The only limitation I can see is that it requires a 3.3VDC input, so it would require a basic converter. Otherwise, would it be difficult to integrate using I2C?
https://www.mouser.com/pdfDocs/TFS20-LDatasheet.pdf
Cheers,
