BendyRuler configuration
Hi all,
Just an update on my situation. My vehicle is an Ackermann-steering rover running firmware version 4.6.2.
I am using a 2D LiDAR that only detects a 60° area in front; all other angles are blocked. The LiDAR data displays normally.
When simple obstacle avoidance is enabled, the vehicle works fine in AUTO mode:
it follows the route accurately and stops normally when encountering obstacles.
However, after setting OA_TYPE = 1, rebooting the flight controller, and configuring all related OA parameters correctly,
the vehicle does not stop for obstacles (because I set AVOID_ENABLE = 0).
If I set AVOID_ENABLE = 7 or 2, the vehicle stops and keeps a safe distance from obstacles, but does not navigate around them — behavior identical to simple avoidance.
How can I make the vehicle actively navigate around obstacles?
Or is there another reason for this issue?
Don’t know the answer to most of your questions but for slide behaviour, you need to set AVOID_BEHAVE to 0, which it normally ought to be by default
It would be helpful if you posted a log file.
Actually yes I tried this today and it does indeed not slide along the obstacles.
My GCS code commands it to just move forward at a given velocity. Next have to try giving it a position target to navigate to and see if if slides then.
the slide function had been canceled long time ago. now it equals to stop function.
but what i want to use is the bendyruler. not simple obstacle avoidance.
Really? When?
Yes I too wanted to use BendyRuler
since a long time ago. maybe since 4.1 version
Can you tell me what messages to look for to debug BendyRuler only navigation?
Also is there a chance that BendyRuler only works for wide FOV sensors are not narrow ones like @Fayeli 's LiDAR?
there’s nothing i can tell you coz i still havent figured how bendyriler works out. i hope get some help from somebody
