Hi Everyone…
While I was trying to fix the focus on my bebop2 camera I boot it up, but the camera was not fitted on the frame only connected facing down.
Since then I only have black screen/no video
I tested bebop2camera on bebop1 and works just fine
and bebop1 camera on bebop2=black screen/no video
SkyController hdmi out same problem
Also tried Bebop2 WebAdmin and so many resets/calibration and even downgrade with no results yet…
Bebop2 failed to Flash after – payload flashing OK – with the following message (displayed through UART connection)
P7R3
P7MU Revision 2
Crystal Frequency: 26000000 Hz
RAM config name: Milos - Dual NT5CC128M16CP-DI - CL11, CWL8 @750MHz 750 Mhz
Milos rev: 2
but 0
USB platform : P7
Wait for connection…
USB host connected, wait for loading…
plf: loading E_TEXT section to addr 0x821e83e8 size 2546256… done.
plf: loading U_DATA section to addr 0x82000000 size 1999846… done.
plf: loading U_BOOTLOADER section to addr 0x80700000 size 291… done.
Executing…
Booting Linux…’ boxinit.serialno=P732P0BG0300008261D0 calib=0x0014003C mtdpa’
[ 0.000000] Booting Linux on physical CPU 0
[ 0.000000] Linux version 3.4.11+ (tpoussevin@colossus) (gcc version 4.6.3 (5
[ 0.000000] CPU: ARMv7 Processor [412fc097] revision 7 (ARMv7), cr=10c53c7d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructie
[ 0.000000] Machine: Milos board
[ 0.000000] P7 per device DMA memory regions:
[ 0.000000] 9ff00000:9fffffff: cast-nand.0
[ 0.000000] 9fe00000:9fefffff: ci_hdrc.0
[ 0.000000] 9fd00000:9fdfffff: ci_hdrc.1
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] On node 0 totalpages: 130304
[ 0.000000] free_area_init_node: node 0, pgdat c04b5f00, node_mem_map c096700
[ 0.000000] Normal zone: 1152 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 129152 pages, LIFO batch:31
[ 0.000000] PERCPU: Embedded 5 pages/cpu @c0def000 s6464 r0 d14016 u32768
[ 0.000000] pcpu-alloc: s6464 r0 d14016 u32768 alloc=8*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pa2
[ 0.000000] Kernel command line: boxinit.serialno=P732P0BG0300008261D0 cal
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 509MB = 509MB total
[ 0.000000] Memory: 504520k/504520k available, 19768k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0439dc0 (4296 kB)
[ 0.000000] .init : 0xc043a000 - 0xc0471940 ( 223 kB)
[ 0.000000] .data : 0xc0472000 - 0xc04b6a60 ( 275 kB)
[ 0.000000] .bss : 0xc04b6a84 - 0xc096651c (4799 kB)
p7: machine setup
[ 0.415717] p7: registering p7-pinctrl.0…
[ 0.416235] p7-pinctrl p7-pinctrl.0: loaded
[ 0.416260] p7: registering user_gpio.-1…
[ 0.416486] ------------[ cut here ]------------
[ 0.416513]WARNING: at /opt/tpoussevin/buildinstaller_last/kernel-p7/linux/)
[ 0.416526] sysfs: cannot create duplicate filename ‘/class/lcd’
[ 0.416561] [] (unwind_backtrace+0x0/0xf8) from [] (warn)
[ 0.416583] [] (warn_slowpath_common+0x50/0x60) from [] )
[ 0.416604] [] (warn_slowpath_fmt+0x30/0x40) from [] (sy)
[ 0.416624] [] (sysfs_add_one+0x90/0xa0) from [] (create)
[ 0.416643] [] (create_dir+0x60/0xbc) from [] (sysfs_cre)
[ 0.416669] [] (sysfs_create_dir+0x90/0xf4) from [] (kob)
[ 0.416690] [] (kobject_add_internal+0x94/0x1dc) from [])
[ 0.416718] [] (kset_register+0x20/0x3c) from [] (__clas)
[ 0.416739] [] (class_register+0xcc/0x1f4) from [] ()
[ 0.416762] [] (__class_create+0x48/0x6c) from [] (p7brd)
[ 0.416786] [] (p7brd_export_fb_positions+0x1c/0x148) from [<c0447)
[ 0.416813] [] (mykonos3x_init_mach+0x14/0x3bc) from [] )
[ 0.416834] [] (customize_machine+0x20/0x28) from [] (do)
[ 0.416853] [] (do_one_initcall+0x9c/0x168) from [] (ker)
[ 0.416879] [] (kernel_init+0x130/0x1cc) from [] (kernel)
[ 0.417004] —[ end trace 1b75b31a2719ed1c ]—
[ 0.417026] ------------[ cut here ]------------
[ 0.417044] WARNING: at /opt/tpoussevin/buildinstaller_last/kernel-p7/linux/)
[ 0.417060] kobject_add_internal failed for lcd with -EEXIST, don’t try to r.
[ 0.417087] [] (unwind_backtrace+0x0/0xf8) from [] (warn)
[ 0.417108] [] (warn_slowpath_common+0x50/0x60) from [] )
[ 0.417129] [] (warn_slowpath_fmt+0x30/0x40) from [] (ko)
[ 0.417149] [] (kobject_add_internal+0x1d8/0x1dc) from [)
[ 0.417172] [] (kset_register+0x20/0x3c) from [] (__clas)
[ 0.417192] [] (class_register+0xcc/0x1f4) from [] ()
[ 0.417212] [] (__class_create+0x48/0x6c) from [] (p7brd)
[ 0.417233] [] (p7brd_export_fb_positions+0x1c/0x148) from [<c0447)
[ 0.417255] [] (mykonos3x_init_mach+0x14/0x3bc) from [] )
[ 0.417274] [] (customize_machine+0x20/0x28) from [] (do)
[ 0.417293] [] (do_one_initcall+0x9c/0x168) from [] (ker)
[ 0.417314] [] (kernel_init+0x130/0x1cc) from [] (kernel)
[ 0.417326] —[ end trace 1b75b31a2719ed1d ]—
NAND device: Manufacturer ID: 0x98, Chip ID: 0xa1 (Toshiba NAND )
[ 0.655166] Scanning device for bad blocks
[ 0.736253] Bad eraseblock 768 at 0x000006000000
hub 1-0:1.0: USB hub found
[ 0.819307] hub 1-0:1.0: 1 port detected
[ 0.819931] gs_bind: controller ‘ci_pdata’ not recognized
[ 0.819955] gadget: Gadget Serial v2.4
[ 0.819974] gadget: g_serial ready
[ 0.820058] i2c /dev entries driver
mmc0: new high speed DDR MMC card at address 0001
[ 3.309730] mmcblk0: mmc0:0001 008GE0 7.28 GiB
[ 3.314712] mmcblk0boot0: mmc0:0001 008GE0 partition 1 4.00 MiB
[ 3.321030] mmcblk0boot1: mmc0:0001 008GE0 partition 2 4.00 MiB
[ 3.327528] usb 1-1: New USB device found, idVendor=0a5c, idProduct=bd1d
[ 3.335223] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.342816] usb 1-1: Product: Remote Download Wireless Adapter
[ 3.342933] mmcblk0: unknown partition table
[ 3.352978] usb 1-1: Manufacturer: Broadcom
[ 3.357000] usb 1-1: SerialNumber: 000000000001
[ 3.363993] mmcblk0boot1: unknown partition table
plf_boot_p7: last_call
external_flasher_run found 2 dir
umounting
/tmp/nand/mnt/update free 26MB(27MB) over 27MB
[ 39.788688] UBIFS: un-mount UBI device 4, volume 0
umounting
/tmp/nand/mnt/data free 8MB(8MB) over 8MB
[ 39.868905] UBIFS: un-mount UBI device 4, volume 1
umounting
/tmp/nand/mnt/@flasher free 10MB(10MB) over 10MB
umounting
/tmp/nand/mnt free 3MB(5MB) over 42MB
[ 40.207778] UBIFS: un-mount UBI device 3, volume 0
ubi_rename_vol on ubi1:1 main_boot -> 0
ubi_rename_vol on ubi1:0 alt_boot -> 0
sysfs_read_int on ubi1:-1 min_io_size=2048
ubi_get_vol_name on ubi1:0 alt_boot
sysfs_read_int on ubi1:0 data_bytes=3548404
sysfs_read_int on ubi1:0 reserved_ebs=67
sysfs_read_int on ubi1:0 usable_eb_size=126976
main size 3548404KB/8507392KB
sysfs_read_int on ubi1:1 data_bytes=4546428
sysfs_read_int on ubi1:1 reserved_ebs=55
sysfs_read_int on ubi1:1 usable_eb_size=126976
alt size 4546428KB/6983680KB
ubi_rename_boot on ubi1 kernel -> 0
[ 40.414395] UBI: mtd1 is detached from ubi1
ubi_detach on ubi1 : 0
sysfs_read_int on ubi2:-1 min_io_size=2048
[ 40.431393] UBI: mtd2 is detached from ubi2
ubi_detach on ubi2 : 0
sysfs_read_int on ubi3:-1 min_io_size=2048
[ 40.438080] UBI: mtd3 is detached from ubi3
ubi_detach on ubi3 : 0
sysfs_read_int on ubi4:-1 min_io_size=2048
[ 40.459563] UBI: mtd4 is detached from ubi4
ubi_detach on ubi4 : 0
can’t open /sys/class/ubi/ubi5/min_io_size device
can’t open /sys/class/ubi/ubi6/min_io_size device
can’t open /sys/class/ubi/ubi7/min_io_size device
can’t open /sys/class/ubi/ubi8/min_io_size device
can’t open /sys/class/ubi/ubi9/min_io_size device
install sucess : 25495488 bytes read
ui status : 11->20
get status 0
can’t open /sys/class/ubi/ubi1/min_io_size device
can’t open /sys/class/ubi/ubi2/min_io_size device
can’t open /sys/class/ubi/ubi3/min_io_size device
can’t open /sys/class/ubi/ubi4/min_io_size device
waitpid 59 59
halting
[ 46.579251] usb 1-1: USB disconnect, device number 2
[ 46.579411] p7-i2cm p7-i2cm.2: shutdown
[ 46.579425] p7-i2cm p7-i2cm.1: shutdown
[ 46.579435] p7-i2cm p7-i2cm.0: shutdown
[ 46.579467] Power down.
[ 46.622610] p7-i2cm p7-i2cm.0: i2c fifo mode without irq is not supported
[ 46.629364] p7-i2cm p7-i2cm.0: i2c fifo mode without irq is not supported
[ 46.636128] p7mu 0-0031: p7mu power off
[ 46.639814] p7-i2cm p7-i2cm.0: i2c fifo mode without irq is not supported
[ 3.378956] mmcblk0boot0: unknown partition table
Can you Guys please help me somehow to reflash the Bebop2?
Any advice would be appreciated…
Thank You
