Hi @mirkix
I’m using the 5.10-ti kernel.
Sure.
I made a migration from pasm to clpru. I’m still trying to understand how to use macros to do conditional compiling but still have no luck.
.global main
; RC AllInOnePRUDShot
; 1 channel RCInput with 5ns accuracy
; 6 DShot channel outputs with 1 Khz of rate
; Timer
.define 200, TICK_PER_US
.define 200000, TICK_PER_MS
; DShot Freq 150 kHz
.define 1333, DSHOT_PERIOD
.define (500 - 150), DSHOT_ZERO_HIGH_PULSE
.define (1000 - 100), DSHOT_ONE_HIGH_PULSE
.define ((DSHOT_PERIOD - DSHOT_ZERO_HIGH_PULSE) - 150), DSHOT_ZERO_LOW_PULSE
.define ((DSHOT_PERIOD - DSHOT_ONE_HIGH_PULSE) - 100), DSHOT_ONE_LOW_PULSE
.define (250 * TICK_PER_US), DSHOT_END_PULSE
;Period of failsafe called
.define (1000 * TICK_PER_MS), FAILSAFE_NEXT_PERIOD
;Ringbuffer size
.define 300, RCIN_RINGBUFFERSIZE
;Register Temp - CLPRU doesn’t support bit manipulation
REG_TEMP1 .set R8
;PRU Constants Table
.define C3, ECAP
.define C24, RAM
.define C26, IEP
;IEP Constants table
.define 0x0, IEP_TMR_GLB_CFG
;.define 0x4, IEP_TMR_GLB_STS
.define 0xc, IEP_TMR_CNT
;.define 0x0, IEP_CNT_ENABLE
;.define 0x4, IEP_DEFAULT_INC
;ECAP Constants table
.define 0x0, ECAP_TSCTR
.define 0x4, ECAP_CTRPHS
.define 0x8, ECAP_CAP1
.define 0xc, ECAP_CAP2
.define 0x10, ECAP_CAP3
.define 0x14, ECAP_CAP4
.define 0x28, ECAP_ECCTL1
.define 0x2a, ECAP_ECCTL2
.define 0x2c, ECAP_ECEINT
.define 0x2e, ECAP_ECFLG
.define 0x30, ECAP_ECCLR
.define 0x32, ECAP_ECFRC
.define 0x5c, ECAP_REVID
;ECCTL1 Constants
.define 0, ECAP_CAP1POL
.define 1, ECAP_CTRRST1
.define 2, ECAP_CAP2POL
.define 3, ECAP_CTRRST2
.define 4, ECAP_CAP3POL
.define 5, ECAP_CTRRST3
.define 6, ECAP_CAP4POL
.define 7, ECAP_CTRRST4
.define 8, ECAP_CAPLDEN
.define 9, ECAP_PRESCALE
.define 14, ECAP_FREE_SOFT
;ECCTL2 Constants tables
.define 0, ECAP_CONT_ONESHT
.define 1, ECAP_STOP_WRAP
.define 3, ECAP_RE_ARM
.define 4, ECAP_TSCTRSTOP
.define 5, ECAP_SYNCI_EN
.define 6, ECAP_SYNCO_SEL
.define 8, ECAP_SWSYNC
.define 9, ECAP_CAP_APWM
.define 10, ECAP_APWMPOL
;ECEINT, ECFLG
.define 0, ECAP_INT
.define 1, ECAP_CEVT1
.define 2, ECAP_CEVT2
.define 3, ECAP_CEVT3
.define 4, ECAP_CEVT4
.define 5, ECAP_CNTOVF
.define 6, ECAP_PRDEQ
.define 7, ECAP_CMPEQ
;RAM OFFSETS
.define (0 * 4), CH_ENABLE_RAM_OFFSET
.define (1 * 4), CH_1_CURRENT_BIT_POSITION_RAM_OFFSET
.define (2 * 4), CH_1_FRAME_RAM_OFFSET
.define (3 * 4), CH_2_CURRENT_BIT_POSITION_RAM_OFFSET
.define (4 * 4), CH_2_FRAME_RAM_OFFSET
.define (5 * 4), CH_3_CURRENT_BIT_POSITION_RAM_OFFSET
.define (6 * 4), CH_3_FRAME_RAM_OFFSET
.define (7 * 4), CH_4_CURRENT_BIT_POSITION_RAM_OFFSET
.define (8 * 4), CH_4_FRAME_RAM_OFFSET
.define (9 * 4), CH_5_CURRENT_BIT_POSITION_RAM_OFFSET
.define (10 * 4), CH_5_FRAME_RAM_OFFSET
.define (11 * 4), CH_6_CURRENT_BIT_POSITION_RAM_OFFSET
.define (12 * 4), CH_6_FRAME_RAM_OFFSET
.define (13 * 4), CH_7_PULSE_TIME_RAM_OFFSET
.define (14 * 4), CH_7_T_TIME_RAM_OFFSET
.define (15 * 4), CH_8_PULSE_TIME_RAM_OFFSET
.define (16 * 4), CH_8_T_TIME_RAM_OFFSET
.define (17 * 4), CH_9_PULSE_TIME_RAM_OFFSET
.define (18 * 4), CH_9_T_TIME_RAM_OFFSET
.define (19 * 4), CH_10_PULSE_TIME_RAM_OFFSET
.define (20 * 4), CH_10_T_TIME_RAM_OFFSET
.define (21 * 4), CH_11_PULSE_TIME_RAM_OFFSET
.define (22 * 4), CH_11_T_TIME_RAM_OFFSET
.define (23 * 4), CH_12_PULSE_TIME_RAM_OFFSET
.define (24 * 4), CH_12_T_TIME_RAM_OFFSET
.define (25 * 4), FAILSAFE_RAM_OFFSET
.define (26 * 4), TIME_OFFSET
.define (27 * 4), MAX_CYCLE_TIME_OFFSET
.define 0x1000, RCIN_RING_HEAD_OFFSET
.define 0x1002, RCIN_RING_TAIL_OFFSET
.define 0x1004, RCIN_RINGBUFFER_RAM_OFFSET
;POCKET
;#ifdef POCKET
;.if $defined(POCKET)
; .define r30.t7, RC_CH_1_PIN
; .define r30.t4, RC_CH_2_PIN
; .define r30.t1, RC_CH_3_PIN
; .define r30.t5, RC_CH_4_PIN
; .define r30.t2, RC_CH_5_PIN
; .define r30.t6, RC_CH_6_PIN
; .define 7, RC_CH_1_BIT
; .define 4, RC_CH_2_BIT
; .define 1, RC_CH_3_BIT
; .define 5, RC_CH_4_BIT
; .define 2, RC_CH_5_BIT
; .define 6, RC_CH_6_BIT
;.endif
;BBBMINI
; .if $defined(BBBMINI)
.define r30.t10, RC_CH_1_PIN
.define r30.t8, RC_CH_2_PIN
.define r30.t11, RC_CH_3_PIN
.define r30.t9, RC_CH_4_PIN
.define r30.t7, RC_CH_5_PIN
.define r30.t5, RC_CH_7_PIN
.define r30.t4, RC_CH_8_PIN
.define r30.t3, RC_CH_9_PIN
.define r30.t2, RC_CH_10_PIN
.define r30.t1, RC_CH_11_PIN
.define r30.t0, RC_CH_12_PIN
.define 10, RC_CH_1_BIT
.define 8, RC_CH_2_BIT
.define 11, RC_CH_3_BIT
.define 9, RC_CH_4_BIT
.define 7, RC_CH_5_BIT
.define 5, RC_CH_7_BIT
.define 4, RC_CH_8_BIT
.define 3, RC_CH_9_BIT
.define 2, RC_CH_10_BIT
.define 1, RC_CH_11_BIT
.define 0, RC_CH_12_BIT
; .endif
; .if $defined(BBBLUE)
; .define r30.t8, RC_CH_1_PIN
; .define r30.t10, RC_CH_2_PIN
; .define r30.t9, RC_CH_3_PIN
; .define r30.t11, RC_CH_4_PIN
; .define r30.t6, RC_CH_5_PIN
; .define r30.t7, RC_CH_6_PIN
; .define r30.t4, RC_CH_7_PIN
; .define r30.t5, RC_CH_8_PIN
; .define 8, RC_CH_1_BIT
; .define 10, RC_CH_2_BIT
; .define 9, RC_CH_3_BIT
; .define 11, RC_CH_4_BIT
; .define 6, RC_CH_5_BIT
; .define 7, RC_CH_6_BIT
; .define 4, RC_CH_7_BIT
; .define 5, RC_CH_8_BIT
; .endif
;#ifdef BBBLUE
;#define RC_CH_1_PIN r30.t8
;#define RC_CH_2_PIN r30.t10
;#define RC_CH_3_PIN r30.t9
;#define RC_CH_4_PIN r30.t11
;#define RC_CH_5_PIN r30.t6
;#define RC_CH_6_PIN r30.t7
;#define RC_CH_7_PIN r30.t4
;#define RC_CH_8_PIN r30.t5
;#endif
;#ifdef POCKET
;#define RC_CH_1_PIN r30.t7
;#define RC_CH_2_PIN r30.t4
;#define RC_CH_3_PIN r30.t1
;#define RC_CH_4_PIN r30.t5
;#define RC_CH_5_PIN r30.t2
;#define RC_CH_6_PIN r30.t6
;#endif
;RCOut enable bits
.define 0, RC_CH_1_ENABLE
.define 1, RC_CH_2_ENABLE
.define 2, RC_CH_3_ENABLE
.define 3, RC_CH_4_ENABLE
.define 4, RC_CH_5_ENABLE
.define 5, RC_CH_6_ENABLE
.define 6, RC_CH_7_ENABLE
.define 7, RC_CH_8_ENABLE
.define 8, RC_CH_9_ENABLE
.define 9, RC_CH_10_ENABLE
.define 10, RC_CH_11_ENABLE
.define 11, RC_CH_12_ENABLE
;Register struct
RegisterStruct .struct
ch_enable .uint
ch_1_next_time .uint
ch_2_next_time .uint
ch_3_next_time .uint
;ch_0_next_time .uint
ch_4_next_time .uint
ch_5_next_time .uint
ch_6_next_time .uint
ch_7_next_time .uint
ch_8_next_time .uint
ch_9_next_time .uint
ch_10_next_time .uint
ch_11_next_time .uint
ch_12_next_time .uint
next_failsafe .uint
time .uint
time_max .uint
time_cycle .uint
rcin_ram_pointer .uint
rcin_ram_pointer_index .uint
rcin_ram_pointer_index_max .uint
rcin_ram_pointer_head .uint
rcin_ram_pointer_tail .uint
temp .uint
temp1 .uint
test .uint
RegisterStructlen .endstruct
register .sassign R3, RegisterStruct
;RegisterChannel .struct
;ch_4_next_time .uint
;ch_5_next_time .uint
;ch_6_next_time .uint
;ch_7_next_time .uint
;ch_8_next_time .uint
;ch_9_next_time .uint
;ch_10_next_time .uint
;ch_11_next_time .uint
;ch_12_next_time .uint
;next_failsafe .uint
;RegisterChannellen .endstruct
;channelregister .sassign R10, RegisterChannel
RCOUT_PWM .macro RC_CH_X_PIN, CH_X_NEXT_TIME, CH_X_ENABLE, CH_X_PULSE_TIME_RAM_OFFSET, CH_X_T_TIME_RAM_OFFSET, RC_CH_X_BIT
;pwm:
;Check if channel is enabled
qbbc pwmend?, register.ch_enable, CH_X_ENABLE
lbco ®ister.time, IEP, IEP_TMR_CNT, 4
;Handle arithmetic and counter overflow, check if there is something to do
sub register.temp, CH_X_NEXT_TIME, register.time
ldi32 register.temp1, 0xF0000000
qbgt pwmend?, register.temp, register.temp1
;mov CH_X_NEXT_TIME, register.time
;Set pin or clear pin?
qbbs pwmclear?, R30, RC_CH_X_BIT
;Load pulse duration
lbco ®ister.temp, RAM, CH_X_PULSE_TIME_RAM_OFFSET, 4
;Calculate time to next event
add CH_X_NEXT_TIME, CH_X_NEXT_TIME, register.temp
;Do not set pin if pulse time is 0
qbeq pwmend?, register.temp, 0
;Set pin
set RC_CH_X_PIN
jmp pwmend?
pwmclear?:
;Load pulse time
lbco ®ister.temp1, RAM, CH_X_PULSE_TIME_RAM_OFFSET, 4
;Load T time
lbco ®ister.temp, RAM, CH_X_T_TIME_RAM_OFFSET, 4
;Calculate time to next event (T - pulse duration)
sub register.temp, register.temp, register.temp1
;Clear pin
clr RC_CH_X_PIN
pwmend?:
.endm
RCOUT_DSHOT .macro RC_CH_X_PIN, CH_X_NEXT_TIME, CH_X_ENABLE, CH_X_CURRENT_BIT_POSITION_RAM_OFFSET, CH_X_FRAME_RAM_OFFSET, RC_CH_X_BIT
qbbc dshotend?, register.ch_enable, CH_X_ENABLE
qbgt dshotend?, register.temp, register.temp1
;ldi32 register.temp1, DSHOT_END_PULSE
;add CH_X_NEXT_TIME, register.time, register.temp1
;Offset larger than FRAME? No new FRAME.
ldi32 register.temp1, 0x0000000F
lbco ®ister.temp, RAM, CH_X_CURRENT_BIT_POSITION_RAM_OFFSET, 4
;End and wait until new frame.
qbgt dshotendforceupdate?, register.temp1, register.temp
lbco ®ister.temp1, RAM, CH_X_FRAME_RAM_OFFSET, 4
qbbs dshotclear?, R30, RC_CH_X_BIT
;Set pin
set RC_CH_X_PIN
qbbs dshothigh?, register.temp1, register.temp
ldi32 register.temp, DSHOT_ZERO_HIGH_PULSE
jmp dshotend?
dshothigh?:
ldi32 register.temp, DSHOT_ONE_HIGH_PULSE
jmp dshotend?
dshotclear?:
;Clear pin
clr RC_CH_X_PIN
qbbs dshotoffhigh?, register.temp1, register.temp
ldi32 register.temp1, DSHOT_ZERO_LOW_PULSE
add register.temp, register.temp, 1
sbco ®ister.temp, RAM, CH_X_CURRENT_BIT_POSITION_RAM_OFFSET, 4
jmp dshotend?
dshotoffhigh?:
ldi32 register.temp1, DSHOT_ONE_LOW_PULSE
jmp dshotend?
dshotendforceupdate?:
;We force an update the next polling cycle.
ldi32 register.temp, 0
dshotend?:
.endm
RCIN_ECAP_INIT .macro
;Initialize ECAP
ldi32 register.temp, (1 << ECAP_CTRRST1) | (1 << ECAP_CAP1POL) | (1 << ECAP_CTRRST2) | (1 << ECAP_CAPLDEN)
sbco ®ister.temp, ECAP, ECAP_ECCTL1, 4
ldi32 register.temp, (1 << ECAP_STOP_WRAP) | (1 << ECAP_TSCTRSTOP) | (2 << ECAP_SYNCO_SEL)
sbco ®ister.temp, ECAP, ECAP_ECCTL2, 4
.endm
RCIN_ECAP .macro
;New value?
lbco ®_TEMP1, ECAP, ECAP_ECFLG, 4
qbbc rcin_ecap_end, REG_TEMP1, 2
;Copy S0 and S1 duration to temp and temp1
lbco ®ister.temp, ECAP, ECAP_CAP1, 8
;Copy S0 and S1 duration to RAM
sbbo ®ister.temp, register.rcin_ram_pointer, 0, 8
;Clear event flags
ldi32 register.temp, (1 << ECAP_CEVT1) | (1 << ECAP_CEVT2)
sbco ®ister.temp, ECAP, ECAP_ECCLR, 4
;Set new tail value
RCIN_WRITE_TAIL register.rcin_ram_pointer_index
;Update pointer
add register.rcin_ram_pointer_index, register.rcin_ram_pointer_index, 1
add register.rcin_ram_pointer, register.rcin_ram_pointer, 8
;Check end of ringbuffer
qblt rcin_ecap_end, register.rcin_ram_pointer_index_max, register.rcin_ram_pointer_index
ldi register.rcin_ram_pointer, RCIN_RINGBUFFER_RAM_OFFSET
ldi register.rcin_ram_pointer_index, 0
rcin_ecap_end:
.endm
RCIN_WRITE_HEAD .macro RCIN_HEAD
sbbo &RCIN_HEAD, register.rcin_ram_pointer_head, 0, 2
.endm
RCIN_WRITE_TAIL .macro RCIN_TAIL
sbbo &RCIN_TAIL, register.rcin_ram_pointer_tail, 0, 2
.endm
MAX_CYCLE_TIME .macro
lbco ®ister.temp1, IEP, IEP_TMR_CNT, 4
sub register.temp, register.temp1, register.time_cycle
mov register.time_cycle, register.temp1
max register.time_max, register.time_max, register.temp
sbco ®ister.time_max, RAM, MAX_CYCLE_TIME_OFFSET, 4
.endm
INIT .macro
;Reset PWM pins
ldi32 r30, 0x0
;Clear register
zero ®ister, $sizeof(register)
;zero &channelregister, $sizeof(channelregister)
;Initialize max cycle time
sbco ®ister.temp, RAM, MAX_CYCLE_TIME_OFFSET, 4
;Initialize ringbuffer
ldi32 register.rcin_ram_pointer, RCIN_RINGBUFFER_RAM_OFFSET
ldi32 register.rcin_ram_pointer_index_max, RCIN_RINGBUFFERSIZE
ldi32 register.rcin_ram_pointer_head, RCIN_RING_HEAD_OFFSET
ldi32 register.rcin_ram_pointer_tail, RCIN_RING_TAIL_OFFSET
RCIN_WRITE_HEAD register.temp
RCIN_WRITE_TAIL register.temp
;Load balancing
ldi32 register.ch_1_next_time, 1000
ldi32 register.ch_2_next_time, 2000
ldi32 register.ch_3_next_time, 3000
ldi32 register.ch_4_next_time, 4000
;ldi32 register.ch_0_next_time, 4000
ldi32 register.ch_5_next_time, 5000
ldi32 register.ch_6_next_time, 6000
ldi32 register.ch_7_next_time, 7000
ldi32 register.ch_8_next_time, 8000
ldi32 register.ch_9_next_time, 9000
ldi32 register.ch_10_next_time, 10000
ldi32 register.ch_11_next_time, 11000
ldi32 register.ch_12_next_time, 12000
;Disable all channels
ldi32 register.ch_enable, 0x0
sbco ®ister.ch_enable, RAM, CH_ENABLE_RAM_OFFSET, 4
;Initialize empty frames.
sbco ®ister.temp, RAM, CH_1_FRAME_RAM_OFFSET, 4
sbco ®ister.temp, RAM, CH_2_FRAME_RAM_OFFSET, 4
sbco ®ister.temp, RAM, CH_3_FRAME_RAM_OFFSET, 4
sbco ®ister.temp, RAM, CH_4_FRAME_RAM_OFFSET, 4
sbco ®ister.temp, RAM, CH_5_FRAME_RAM_OFFSET, 4
sbco ®ister.temp, RAM, CH_6_FRAME_RAM_OFFSET, 4
sbco ®ister.temp, RAM, CH_7_PULSE_TIME_RAM_OFFSET, 4
sbco ®ister.temp, RAM, CH_8_PULSE_TIME_RAM_OFFSET, 4
sbco ®ister.temp, RAM, CH_9_PULSE_TIME_RAM_OFFSET, 4
sbco ®ister.temp, RAM, CH_10_PULSE_TIME_RAM_OFFSET, 4
sbco ®ister.temp, RAM, CH_11_PULSE_TIME_RAM_OFFSET, 4
sbco ®ister.temp, RAM, CH_12_PULSE_TIME_RAM_OFFSET, 4
;sbco ®ister.temp, RAM, CH_7_T_TIME_RAM_OFFSET, 4
;sbco ®ister.temp, RAM, CH_8_T_TIME_RAM_OFFSET, 4
;sbco ®ister.temp, RAM, CH_9_T_TIME_RAM_OFFSET, 4
;sbco ®ister.temp, RAM, CH_10_T_TIME_RAM_OFFSET, 4
;sbco ®ister.temp, RAM, CH_11_T_TIME_RAM_OFFSET, 4
;sbco ®ister.temp, RAM, CH_12_T_TIME_RAM_OFFSET, 4
;Initialize frame offsets (to empty frames)
ldi32 register.temp, 0x10
sbco ®ister.temp, RAM, CH_1_CURRENT_BIT_POSITION_RAM_OFFSET, 4
sbco ®ister.temp, RAM, CH_2_CURRENT_BIT_POSITION_RAM_OFFSET, 4
sbco ®ister.temp, RAM, CH_3_CURRENT_BIT_POSITION_RAM_OFFSET, 4
sbco ®ister.temp, RAM, CH_4_CURRENT_BIT_POSITION_RAM_OFFSET, 4
sbco ®ister.temp, RAM, CH_5_CURRENT_BIT_POSITION_RAM_OFFSET, 4
sbco ®ister.temp, RAM, CH_6_CURRENT_BIT_POSITION_RAM_OFFSET, 4
;Stop counter - This is important as the IEP timer appears
;to sometimes go into an undefined state if we change other
;parts of the control register while it's counting. Needing
;a hard reset to resume functioning.
;;lbco ®ister.temp, IEP, IEP_TMR_GLB_CFG, 4
;;ldi32 register.temp1, 0xFFFFFFFE
;;and register.temp, register.temp, register.temp1
;;sbco ®ister.temp, IEP, IEP_TMR_GLB_CFG, 4
sbco ®ister.temp1, IEP, IEP_TMR_GLB_CFG, 4
;Configures the IEP counter and enables it
;-> 4.5.4.1 IEP_TMR_GLB_CFG Register in TRM
;-> Reference: https://github.com/beagleboard/am335x_pru_package/blob/master/pru_sw/example_apps/PRU_industrialEthernetTimer/PRU_industrialEthernetTimer.p
; CMP_INC = 1
;DEFAULT_INC = 1
;CNT_ENABLE = 1
;;ldi register.temp, 0x0110
ldi32 register.temp, 0xffffffff
sbco ®ister.temp, IEP, IEP_TMR_CNT, 4
;Resets the counter of IEP timer
;Reset Count Register (CNT) by writing 0xFFFFFFFF to clear
;-> 4.4.3.2.2 Basic Programming Model in TRM
;-> 4.5.4.4 IEP_TMR_CNT Register in TRM
;;ldi32 register.temp, 0xffffffff
;;sbco ®ister.temp, IEP, IEP_TMR_CNT, 4
;Start counter
;;or register.temp, register.temp, 1 << IEP_CNT_ENABLE
ldi32 register.temp, 0x0111
sbco ®ister.temp, IEP, IEP_TMR_GLB_CFG, 2
.endm
;Without this motors would keep spinning if ardupilot disappeared.
FAILSAFE_HANDLING .macro
sub register.temp, register.next_failsafe, register.time
qbgt failsafeend, register.temp, register.temp1
ldi32 register.temp, FAILSAFE_NEXT_PERIOD
add register.next_failsafe, register.time, register.temp
lbco ®_TEMP1, RAM, FAILSAFE_RAM_OFFSET, 4
qbbs failsafe_succesful, REG_TEMP1, 0
sbco ®ister.temp, RAM, CH_ENABLE_RAM_OFFSET, 4
failsafe_succesful:
sbco ®ister.temp, RAM, FAILSAFE_RAM_OFFSET, 4
failsafeend:
.endm
main
INIT
RCIN_ECAP_INIT
mainloop:
lbco ®ister.ch_enable, RAM, CH_ENABLE_RAM_OFFSET, 4
sbco ®ister.time, RAM, TIME_OFFSET, 4
RCOUT_DSHOT RC_CH_1_PIN, register.ch_1_next_time, RC_CH_1_ENABLE, CH_1_CURRENT_BIT_POSITION_RAM_OFFSET, CH_1_FRAME_RAM_OFFSET, RC_CH_1_BIT
RCOUT_DSHOT RC_CH_2_PIN, register.ch_2_next_time, RC_CH_2_ENABLE, CH_2_CURRENT_BIT_POSITION_RAM_OFFSET, CH_2_FRAME_RAM_OFFSET, RC_CH_2_BIT
RCOUT_DSHOT RC_CH_3_PIN, register.ch_3_next_time, RC_CH_3_ENABLE, CH_3_CURRENT_BIT_POSITION_RAM_OFFSET, CH_3_FRAME_RAM_OFFSET, RC_CH_3_BIT
RCOUT_DSHOT RC_CH_4_PIN, register.ch_4_next_time, RC_CH_4_ENABLE, CH_4_CURRENT_BIT_POSITION_RAM_OFFSET, CH_4_FRAME_RAM_OFFSET, RC_CH_4_BIT
RCOUT_DSHOT RC_CH_5_PIN, register.ch_5_next_time, RC_CH_5_ENABLE, CH_5_CURRENT_BIT_POSITION_RAM_OFFSET, CH_5_FRAME_RAM_OFFSET, RC_CH_5_BIT
RCOUT_DSHOT RC_CH_6_PIN, register.ch_6_next_time, RC_CH_6_ENABLE, CH_6_CURRENT_BIT_POSITION_RAM_OFFSET, CH_6_FRAME_RAM_OFFSET, RC_CH_6_BIT
FAILSAFE_HANDLING
;.if $defined(BBBMINI)
;RCOUT_DSHOT RC_CH_7_PIN, register.ch_7_next_time, RC_CH_7_ENABLE, CH_7_CURRENT_BIT_POSITION_RAM_OFFSET, CH_7_FRAME_RAM_OFFSET, RC_CH_7_BIT
;RCOUT_DSHOT RC_CH_8_PIN, register.ch_8_next_time, RC_CH_8_ENABLE, CH_8_CURRENT_BIT_POSITION_RAM_OFFSET, CH_8_FRAME_RAM_OFFSET, RC_CH_8_BIT
;RCOUT_DSHOT RC_CH_9_PIN, register.ch_9_next_time, RC_CH_9_ENABLE, CH_9_CURRENT_BIT_POSITION_RAM_OFFSET, CH_9_FRAME_RAM_OFFSET, RC_CH_9_BIT
;RCOUT_DSHOT RC_CH_10_PIN, register.ch_10_next_time, RC_CH_10_ENABLE, CH_10_CURRENT_BIT_POSITION_RAM_OFFSET, CH_10_FRAME_RAM_OFFSET, RC_CH_10_BIT
;RCOUT_DSHOT RC_CH_11_PIN, register.ch_11_next_time, RC_CH_11_ENABLE, CH_11_CURRENT_BIT_POSITION_RAM_OFFSET, CH_11_FRAME_RAM_OFFSET, RC_CH_11_BIT
;RCOUT_DSHOT RC_CH_12_PIN, register.ch_12_next_time, RC_CH_12_ENABLE, CH_12_CURRENT_BIT_POSITION_RAM_OFFSET, CH_12_FRAME_RAM_OFFSET, RC_CH_12_BIT
;.endif
;.if $defined(BBBLUE)
;.endif
;RCOUT_PWM RC_CH_7_PIN, register.ch_7_next_time, RC_CH_7_ENABLE, CH_7_PULSE_TIME_RAM_OFFSET, CH_7_T_TIME_RAM_OFFSET, RC_CH_7_BIT
;RCOUT_PWM RC_CH_8_PIN, register.ch_8_next_time, RC_CH_8_ENABLE, CH_8_PULSE_TIME_RAM_OFFSET, CH_8_T_TIME_RAM_OFFSET, RC_CH_8_BIT
;RCOUT_PWM RC_CH_9_PIN, register.ch_9_next_time, RC_CH_9_ENABLE, CH_9_PULSE_TIME_RAM_OFFSET, CH_9_T_TIME_RAM_OFFSET, RC_CH_9_BIT
;RCOUT_PWM RC_CH_10_PIN, register.ch_10_next_time, RC_CH_10_ENABLE, CH_10_PULSE_TIME_RAM_OFFSET, CH_10_T_TIME_RAM_OFFSET, RC_CH_10_BIT
;RCOUT_PWM RC_CH_11_PIN, register.ch_11_next_time, RC_CH_11_ENABLE, CH_11_PULSE_TIME_RAM_OFFSET, CH_11_T_TIME_RAM_OFFSET, RC_CH_11_BIT
;RCOUT_PWM RC_CH_12_PIN, register.ch_12_next_time, RC_CH_12_ENABLE, CH_12_PULSE_TIME_RAM_OFFSET, CH_12_T_TIME_RAM_OFFSET, RC_CH_12_BIT
RCIN_ECAP
;MAX_CYCLE_TIME
jmp mainloop
