From my research the AS150U battery connector is only rated for 70a continuous and 140a peak.
Seems odd since most heavy lift drone batteries come with these connectors, but most heavy lift drones are going to need 120a continuous and 240a peak.
Do they handle this higher than rated current fine or instead of 1x 30000mah battery with the AS150U connector do I need 2x 16000mah batteries in parallel and have 2 plugs going into my main power wire?
Also noticed that 8awg is supposed to be the biggest wire for those connectors, is that going to be handle the current?
Weird to have a 25c battery with a connector thats rated a peak of under 5c.
People are getting away with a lot . Manufacturer current ratings typically are pretty conservative but if you are building something supposed to be reliable I wouldn’t push. Personally I would go with higher voltage or bigger connector if you are exceeding connector current rating.
The problem is, at least as far as I am concerned, drone technology started small and there has never been a real standard for it. In the early stages we had to deal with all sort of connectors and wire sizes. At least in recent years the TX60 and TX90 connectors been frequently used and widely available. But once again, not really suitable for your applications. Also the wires are based on automotive and US standards. Not really suitable for the much larger drones out there.
The challenge, for you and everyone building large, powerful drones, to find what works best and doesn’t cause issues with size and weight. → Industrial supplies appear to be the most appropriate for such projects. Both for wires / cables and connectors.
Perhaps something like the Anderson plug would be suitable.
Note on safety: Another issue, from a technician perspective at least, to this day most drones and RC models do not have any fuses or other protection which would cut off at power source in the event of excessive electrical current.
Many wires are technically speaking under-sized, yet due to limited flying time most get away with it. → Different story on endurance drones and aircraft.
The thermal side matters more than the peak number here. Those AS150U peaks are momentary, so pulling 120A continuous through a single plug means sustained heating in a small contact area, and heat is what actually degrades the housing and contacts. Running two packs in parallel halves current per connector, which is the safer route even with the extra weight and wiring. On 8AWG, it’s fine for short runs if the insulation is rated for the heat, but fuse or breaker protection is worth adding — LupusTheCanine’s point about conservative ratings is fair, though ‘getting away with it’ usually just means short flights.
Fuse or Breaker protection is another heat source, in fact it’s triggered by heat building up, and can be an unexpected power outage.
Particularly with a multirotor, where there is no chance to glide or autorotate, the ESCs must be the “fuse” unfortunately.
I suspect Andersen plugs are not appropriate - the current carrying capacity for their weight and size is probably not as good as an AS150.
