Bat1 0.00v 0.2 A 99%! Motor working, wrong battery reading after accident
Everything was working fine yesterday, but the drone had an accident and fell over (180%) and continued spinning on ground backward, and one prop was broken and battery with adapter were damaged.
I changed batter, adapter, prop and connected again and recallibrated ESC correctly, and tried Motor test, and worked well. I also measured battery output voltage: 25V, and output from the batter module is 25V.
I am using:
  • Holybro 650x
  • 12,000 mA Lipo batter, 6c
  • Using battery module: “PM02D-v1”
  • Pixhawk 6x
  • Mission Planner
Parameters: https://www.dropbox.com/scl/fi/v3lezqzq0x99d5bs7corw/07_May_2025_params.param?rlkey=1xwfofncro3lb4xnydyd2lfbc&st=5xfe148x&dl=0
Fixed. Power Module was reading wrong voltage, probably internal damage.
