Barometer error message when using new GPS module
hi guys. help required. trying to configure my Mario5 with speedybee f405 v4 board but evrytime error msg appears that
BAROMETER: DRIVERS NOT FOUND . i have done every thing regarding wiring rewiring the NEW HGLRC m100 gps with compass module.
when i remove sda and scl wires it shows fine but without compass but with compass scl sda plugged in again same error msg pops up.
iam sure that board is not not shorted iam sure that gps module is intact.
pl help
A GPS/compass module would not cause barometer errors.
The most likely cause is use of the wrong firmware. Be sure you are selecting the speedybeef4v4 firmware target for upload.
Thanks Yuri for update..but i checked in detail firmware is correct..when i unplug the scl and sda wires then the Mission Planner is responding normaly..but with both wires on again same error message appears
Double check that you are connecting SDA and SDL properly. If connected in reverse, you may be disrupting the I2C bus.
We only know details you described of your system. So if you only state that everything is fine and correct no one can help you.
So show in detail pin by pin your connections between FC and GPS (description and photo)
And show by a log.bin file that you used the correct firmware
sure i will do that, thanks.
