I have a heli user that experienced a similar behavior posted here where the desired pitch and roll angles were very high before takeoff. The user was also using version 4.1.1.
I would recommend that you upgrade your version to the latest stable version which is 4.1.5. Then before you takeoff verify in your ground control station that your desired lean angles are at appropriate values which should be zero. If you see this same behavior in 4.1.5 please post a log file in this thread.
Upgrade to 4.1.5. There could be patches that fixed this issue but I never heard anyone having this kind of problem. Nonetheless, monitor the desired angles through mission planner prior to launching. I don’t remember the exact signal names in mavlink but I’m fairly positive they are there. If you are able to reproduce this, then use the log_disarmed parameter to log all of the data even prior to arming. Then post it here. It will help determine if it is unique to your setup or a true bug.
@LIRANFAB Liran,
Before I do anymore troubleshooting, I would like you to upgrade to the latest stable version. See if you are still experiencing this issue with the latest stable and we can go from there.
Thanks
Bill
