Autotune takes more than 14 minutes per axis
I have ZMR250 frame and Pixhawk 2.4.8 mounted with dampers, and can confirm that:
  • There is no much noise level from gyro
  • There is no flexible payload on the copter
  • Isolation mount is hard enough
  • ESC have linear response
Still 14 minutes was not enough to setup Pitch axis, logs sometimes was saying that is
Success 3/4
and than
Success 0/4
I have tried it couple times in PosHold and AltHold modes, still no luck. With no wind.
https://youtu.be/5SNTu6EnFtQ - Video recorded during autotuning
could you please send BIN log file of this flight ?
Set FLTT to 0 while running autotune if you are on 4.0.x - this is especially important on small copters
