I flew my new, very heavy (460 g) Nano Goblin plane today in low wind conditions (around 2 m/s). I took off in FBWA mode, then immediately switched to Autotune mode when it was in the air. During the flight, the plane only seemed to get less responsive and harder to control. This is confirmed when I look at the log file (EDIT: I uploaded the wrong log before, this is the right one: 2024-08-12 07-37-45.bin - Google Drive): for axis 0 (pitch?), the P coefficient drops from 0.08 to 0.0036, the I coefficient drops from 0.15 to 0.0036, and FF goes from 0.34 to 0.074, although D shoots up from 0 (?) to 0.004. The same story holds for axis 1, although the drop isn’t as severe. 45 seconds into the flight, I crashed, apparently just because of pilot error (the logs say I pushed the nose down…even though I could have sworn I pulled up). I glued the plane back together and tried to fly it again, but it just fell to the ground instead of taking off after I threw it, likely because the new PID settings made the plane extremely unresponsive.
What am I doing wrong? What are some good default parameters I can set the PID values to for the Nano Goblin so that I can at least fly the thing without crashing and having to glue it back together?
Details of my setup:
FC: Mateksys F405 WMN
Ardupilot version: Plane 4.5.4
Radio controller: RadioMaster TX12 MkII 2.4 GHz
GPS & compass: HGLRC M100-5883
