I am processing the AutoTune flights according to this Table.
During flight #2 I got the message mentioned in the title.
What can I do ?
@twistedwings I was able to pull off enough information to maybe help tune the pitch axis a little better and see if you can have it run the pitch tuning for rate P and Rate D again. Make the following changes
ATC_RAT_PIT_P = 0.035
ATC_RAT_PIT_D = 0.003
If it fails again then move on to the roll tuning for Rate P and Rate D.
Thank you very much !
I will give that a try on the next calm day.
Unfortunately it failed again.
So I’ll skip this one and continue with roll.
I looked at your log. The roll axis looks pretty good based on the frequency sweep and what I predicted the gains should be. The default gains are pretty close so I would not touch them. I think you can raise your I gains for pitch and roll to 0.1. So set these params
ATC_RAT_PIT_I = 0.1
ATC_RAT_RLL_I = 0.1
I want you to set these params as well and run the tune check sequence on pitch and roll and post the log
ATC_ANG_PIT_P 6
ATC_ANG_RLL_P 6
If your autopilot is mounted on a compliant vibration damper, it can work against you like this. Recommend a firmer, more direct-to-frame mount if this is the case.
thank you for the support.
I changed the params and ran the tune check.
