On that size of motor you should be fine. I know there were issues with someone having too small a cap on those ESCs so worth checking. Note that the higher the ramp rate the more need for a good cap as well.
Just to update…
Last night I downgraded the firmware on my esc’s to 2.18. Just ran fully through autotune and no issues at all. I have flown several times and no issues yet.
AM32 after update should be set to defaults, and then re-apply settings You are interested in. I would recommend PWM type by RPM and auto timing advance.
Seems there are some changes in way settings are stored and they are getting messed up after update 2.18 → 2.19. At least that is my experience.
Update…
I flew several packs today and have had zero issues since downgrading to 2.18 firmware.
I may in the future flash 2.19 again and see if it continues to do what it did or not.
Is there any guidance or rule of thumb on the slew rate based on KV/prop size yet for Arducopter? Have you got any suggestion on how to test this non-destructively?
I literally have two datapoints:
- I have identical quads with 2150kv 6S motors, one on AM32, one on BLHeli 32.9. 12% slew rate gives me approximately the same tune on the AM32 one as the BLHeli one.
- Pete said use 8-10% on 1000kv motors with 10” props.
That’s it.
Higher slew rate will generate more torque which on larger motors with bigger props stands a higher chance of desync. But it obviously depends on a number of factors.
