Hi there.
I recently moved my autopilot into a flying wing and so I had to set it up for elevons. after a small crash and with the help from DIYDrones I learnt that the autopilot was not correcting its elevons in the correct direction. I then changed the neccessary setting in the radiocalibration tab and it now corrects as it should.
However, now the autopilot does not respond to any of the elevon inputs I provide. it responds to throttle and switches modes just fine but does not respond to any of my stick inputs.
When I swap into manual mode it works fine. This is very strange because it used to respond to my stick inputs in FBWA mode until I changed the settings to reverse elevons. when I change it back to how it used to be it still does not work.
When I changed the settings so that elevons were reversed I had to use a different computer to the one I normally use. This required that I Install windows 8 APM drivers for the laptop and Install APM 2.
Does anyone have any clue as to how I should go about diagnosing the problem and fixing it?
Cheers!
Hayden
