I’ve been experimenting with airplane auto landings and have had multiple successful landings. Amazing. I’m using a Pixracer, Arduplane 3.8.4 and Mission Planner 1.3.56. I am using barometric altitude (no rangefinder) to sense altitude.
Am also using a sequenced landing approach where the turn to base leg and turn to final approach both have glide slopes of about 10%. I’ve tried higher and lower glide slopes with similar overshoot results. Also tried longer distances but the airplane still overshot the spot.
I’ve increased the LAND_FLARE_SEC parameter from the default of 2 to 3 thinking that the motor would turn off sooner. It didn’t.
I’ve tried a few different values for the LAND_FLARE_ALT parameter but put it back at the default of 3 meters because changing it made little difference.
The airplanes flares and lands nicely, but it overshoots the programmed landing spot every time by about 100 to 200 feet.
In the flight plan is the final waypoint designated LAND the landing spot or the beginning of the landing sequence?
What else could I try?
Thanks,
Paul
