Assigning waypoints to ArduPlane plane with Pymavlink
With the code I wrote, I was able to take off the plane using the AUTO_TAKEOFF command. However, I want to send a waypoint with MISSION_ITEM afterwards. However, the mission is not accepted. Also, in order to be able to do the mission, I put the plane in AUTO mode after the plane takes off. However, the plane does not go to AUTO mode but to RTL mode. Can you help me with this?
