So basically what the title says. I only want basic pose estimation. Exact flow hold may not be necessary. It is for an indoor drone with a max speed limited to about 1m/s or lower. The cheapest I could find is an ADNS3080 but that isn’t supported, so the next cheapest is PMW3901 which is nearly 3x the cost of ADNS3080.
EDIT: Is MTF-02 good?
Allister
(Allister Schreiber)
December 15, 2025, 3:13pm
2
I’ve used the MTF-01P and it’s been great for the price. The range numbers are a bit optimistic for outdoor use, but that’s pretty common.
Cool, I don’t plan, on hovering more than 1m indoors. Outdoors, I could have used a GPS
Would I set FLOW_TYPE to MAVLINK for an MTF02?
Allister
December 16, 2025, 2:42pm
5
Probably.
They’ve got pretty good instructions on their website.
Here’s my settings:
FLOW_TYPE 5.000000 # MAVLink
RNGFND1_ADDR 0.000000
RNGFND1_FUNCTION 0.000000 # Linear
RNGFND1_GNDCLEAR 16.000000 #Depends on your frame
RNGFND1_MAX_CM 800.000000
RNGFND1_MIN_CM 1.000000
RNGFND1_OFFSET 0.000000
RNGFND1_ORIENT 25.000000 # Down
RNGFND1_PIN -1.000000 # Not Used
RNGFND1_RMETRIC 1.000000 # Yes
RNGFND1_SCALING 3.000000
RNGFND1_STOP_PIN -1.000000 # Not Used
RNGFND1_TYPE 10.000000 # MAVLink
The rest are calibration (setup dependent) and EKF3 settings (depends on how you want to use it)
