I have a Pixhawk 4 that I am using to control 6 underwater thrusters via a power distribution module. I have the pixhawk connected to a Jetson orin Nano where I am running ROS2 Humble to send python commands to the pixhawk. This is for an underwater sub so I have the pixhawk configured for ArduSub mode. I have a GPS and barometric sensor connected for testing purposes (I know that GPS does not work underwater) because I do not have a doppler velocity log, pinger, or other position source. I previously tried setting the sub to guided mode, but this failed because it was not able to obtain position. My next effort is to try getting it to work with guided_nogps mode but have not been successful. I have not found a guided_nogps option in either QGC or Mission Planner, and do not see documentation for it online, but have seen people discussing this mode in other forums. I have included my Pub/Sub files which are run from a launch file, but when I execute the code, the thrusters will not actually move. I do know that they are hooked up correctly because if I put it in stabilize mode the thrusters stabilize, and if I put it in manual mode they will run only if I publish separate commands in a different terminal on the jetson. However, this will not work for my case because I want the sub to run fully autonomously after I have run the one python launch file and I do not want it to be tethered or have a controller connected. I am also eventually going to have a camera connected to receive input via opencv and yolo and have the sub respond based on what it sees, but am just trying to get the thrusters to operate on their own for now. Does anyone see an issue with my code or know why this may not be working?
Sub_controller.py:
import rclpy
from rclpy.node import Node
from std_msgs.msg import String
import time
from pymavlink import mavutil
class SubController(Node):
def __init__(self):
super().__init__('sub_controller')
self.publisher = self.create_publisher(String, 'sub_status', 10)
self.get_logger().info("Connecting to Pixhawk...")
self.master = mavutil.mavlink_connection('/dev/ttyTHS1', baud=115200)
# Wait for connection
self.master.wait_heartbeat()
self.get_logger().info("Heartbeat received. Connected to Pixhawk.")
# Ensure running ArduSub firmware
if not self.check_ardusub():
self.get_logger().error("Not running ArduSub! Exiting.")
return
# Set mode to GUIDED_NOGPS
if not self.set_mode('GUIDED_NOGPS'):
self.get_logger().error("Failed to set GUIDED_NOGPS mode. Exiting.")
return
# Arm the vehicle
if not self.arm():
self.get_logger().error("Failed to arm thrusters. Exiting.")
return
# Publish ready status
ready_msg = String()
ready_msg.data = "ready"
self.publisher.publish(ready_msg)
self.get_logger().info("Pixhawk is ready. Waiting for mission commands...")
# Subscribe to mission commands
self.subscription = self.create_subscription(
String,
'sub_commands',
self.command_callback,
10)
def check_ardusub(self):
"""Verify the vehicle is running ArduSub firmware."""
msg = self.master.recv_match(type='HEARTBEAT', blocking=True, timeout=2)
return msg and msg.autopilot == mavutil.mavlink.MAV_AUTOPILOT_ARDUPILOTMEGA
def set_mode(self, mode):
"""Set the vehicle mode."""
self.get_logger().info(f"Setting mode to {mode}...")
mode_id = self.master.mode_mapping().get(mode)
if mode_id is None:
self.get_logger().error(f"Mode {mode} not available.")
return False
self.master.mav.set_mode_send(
self.master.target_system,
mavutil.mavlink.MAV_MODE_FLAG_CUSTOM_MODE_ENABLED,
mode_id
time.sleep(2)
for _ in range(5):
msg = self.master.recv_match(type='HEARTBEAT', blocking=True, timeout=1)
if msg and msg.custom_mode == mode_id:
self.get_logger().info(f"Successfully set mode to {mode}.")
return True
self.get_logger().error(f"Failed to switch to {mode} mode.")
return False
def arm(self):
"""Arm the vehicle and verify."""
self.get_logger().info("Arming thrusters...")
self.master.mav.param_set_send(
self.master.target_component,
b'ARMING_CHECK',
0,
mavutil.mavlink.MAV_PARAM_TYPE_REAL32
time.sleep(2)
# Send arm command
self.master.mav.command_long_send(
mavutil.mavlink.MAV_CMD_COMPONENT_ARM_DISARM,
0,
1, # 1 = arm
0, 0, 0, 0, 0, 0
time.sleep(2)
for _ in range(5):
if msg and (msg.base_mode & mavutil.mavlink.MAV_MODE_FLAG_SAFETY_ARMED):
self.get_logger().info("Thrusters armed successfully.")
return True
self.get_logger().error("Failed to arm thrusters.")
return False
def command_callback(self, msg):
"""Handle movement commands from mission_executor."""
command = msg.data
self.get_logger().info(f"Received command: {command}")
if command == "move_forward":
self.move_forward(2)
elif command == "turn_left":
self.turn_left()
elif command == "stop":
self.stop()
else:
self.get_logger().warn(f"Unknown command: {command}")
def move_forward(self, distance):
"""Move forward using thrust control in GUIDED_NOGPS mode."""
self.get_logger().info(f"Moving forward {distance} feet...")
velocity = 0.3
duration = distance / velocity
self.master.mav.set_attitude_target_send(
0, self.master.target_system, self.master.target_component,
0b00000000, [1.0, 0.0, 0.0, 0.0], 0, -0.3, 0, 0.6
time.sleep(duration)
self.stop()
def turn_left(self):
"""Turn left using yaw control in GUIDED_NOGPS mode."""
self.get_logger().info("Turning left...")
0b00000000, [1.0, 0.0, 0.0, 0.0], 0, 0, 0.5, 0.5
time.sleep(2)
self.stop()
def stop(self):
"""Stop all movement."""
self.get_logger().info("Stopping movement.")
0b00000000, [1.0, 0.0, 0.0, 0.0], 0, 0, 0, 0.5
time.sleep(0.5)
def main(args=None):
rclpy.init(args=args)
node = SubController()
rclpy.spin(node)
rclpy.shutdown()
if __name__ == '__main__':
main()
Mission executer:
import rclpy
import time
class MissionExecutor(Node):
def __init__(self):
super().__init__('mission_executor')
self.publisher = self.create_publisher(String, 'sub_commands', 10)
self.subscription = self.create_subscription(String, 'sub_status', self.status_callback, 10)
self.ready = False
self.get_logger().info("Waiting for sub to be ready...")
def status_callback(self, msg):
"""Wait for confirmation that the sub is ready before starting the mission."""
if msg.data == "ready":
self.get_logger().info("Sub is ready. Starting mission...")
self.ready = True
self.execute_mission()
def execute_mission(self):
if not self.ready:
return # Do nothing if not ready
command = String()
# Step 1: Move forward
command.data = "move_forward"
self.publisher.publish(command)
self.get_logger().info("Commanding forward movement...")
time.sleep(3)
# Step 2: Turn left
command.data = "turn_left"
self.get_logger().info("Commanding left turn...")
time.sleep(3)
# Step 3: Stop
command.data = "stop"
self.get_logger().info("Commanding stop...")
time.sleep(2)
self.get_logger().info("Mission complete. Shutting down.")
rclpy.shutdown()
node = MissionExecutor()
rclpy.spin(node)
rclpy.shutdown()
main()
