My Rover works fine in manual mode, but it spin when I run acro mode.
What should I do? Please help me
Test video
https://youtu.be/-NHybBwXuTY
Test video
Donāt reverse transmitter channels to make manual mode work. Reverse servo channels to make acro mode work.
There should be a note at the top of the Rover Configuration Wiki saying something like. āManual Mode is essentially passthrough, as if there is no Flight Controller presentā.
Please help me. If my rover changes to acro mode, it moves alone. Please watch the video and tell me the solution. I beg you.
There is no problem with the s center value in manual mode, but in acro mode, the center value moves alone.
Follow all steps in this guide very carefully, including radio calibration and motor setup.
