ArduPlane v3.9.1 on an Omnibus Pro F4 v3 RC channel mixed up with R9 mini and Taranis xd9 plus
Hi
I have installed ArduPlane v3.9.1 on an Omnibus Pro F4 v3. I have soldered the ppm PPM solder pad/resistor and in Mission planner I haver RC inputs from the receiver(R9 mini sbus out) with TX is Taranis xd9 plus (mode2.). However on the mission planner radio calibration, the inputs are mixed up. Throttle is responding to the left rudder on the TX and elevator on the TX makes the pitch move. I have tried changing modes on the TX etc but are getting nowhere ?
With previous a Omnibus Pro F4 v3 (sbus pad/resistor soldered) using INAV I never had this input mix up issue with the radio inputs?
The easiest way to solve this is to change the channel order of the taranis. You probably have it set to the TAER order or similar, but arduplane is expecting AETR.
Hi James
looks ok now.
thanks
