ArduPlane RTL failed once during flight, aircraft continued away from home while descending and overspeeding
I would like some help analysing an unusual RTL event from my ArduPlane aircraft. I have used RTL approximately 100 times with this aircraft, and this was the first time I observed this behaviour. During the flight, the aircraft was flying away from home. I manually switched the flight mode to RTL in order to bring it back. However, during this particular event, after switching to RTL
It did not climb toward the configured RTL altitude of 120 m.
Instead, it slowly descended.
It continued approximately in its original direction.
At the same time, the Arduplane oversped the aircraft. Despite AIRSPEED_MAX is 25 m/s.
I eventually had to switch back to manual control to recover from the situation.
In attached video you can see the failed RTL followed by successful RTL few seconds later. I also attached my param file. If you need log or bin file of the flight for further analysis, give me know.
2026-10-02 17-19-30.bin.param (19.2 KB)
We need a .bin log file.
