I try change follower plane speed with AIRSPEED_ params, but can not changing. I want to detect the leader plane on the follower plane’s camera. So I have to fly a little closer. The distance right now is 115m. The speed of both is 13 - 14m/s
The follow parameters only apply on the follow plane. They have no effect on the leader.
The obvious problem is FOLL_SYSID on the follow plane- this should be the SYSID_THISMAV of the leader plane. The leader plane and follow plane must have different SYSID_THISMAV values.
The other problem I see is FOLL_DIST_MAX - this will stop following as soon as the follow plane is > 100m from the leader. Definitely not what you want. You should set this to something large like 1000.
If you are running the plane_follow.lua script you should also have a set of ZP* parameters - please post those.
When I say ‘param show ZP*’ I don’t get any output. I connect via UDP in Python code, not a Lua script, and enter the latitude, longitude and altitude values of the plane (ROS2 topic) as parameters to the MAV_CMD_NAV_WAYPOINT command with Pymavlink mission_item_send(). Since I’m running ROS2 Humble, it’s constantly doing this in a loop. He follows but cannot get close.
Follower:
GUIDED> param show ZP*
GUIDED>
Ah! Follow mode is not fully implemented in Plane, hence my script. If you look at my plane_follow.lua script, I had to add some logic, including two PID controllers to get the follow plane to correctly match the speed of the leader.
If you are trying to implement this in python or ROS2, you have a lot of work to do.
