Hello, @rhys, first of all, thank you for the help, I appreciate it.
Secondly, I ran the commands and I provide you the output.
1.
sim_vehicle.py -v ArduCopter -f quad --console --map\n
SIM_VEHICLE: Start
SIM_VEHICLE: Killing tasks
SIM_VEHICLE: Starting up at SITL location
SIM_VEHICLE: WAF build
SIM_VEHICLE: Configure waf
SIM_VEHICLE: “/home/acharchalioti/sim_ws/src/ardupilot/modules/waf/waf-light” “configure” “–board” “sitl”
Setting top to : /home/acharchalioti/sim_ws/src/ardupilot
Setting out to : /home/acharchalioti/sim_ws/src/ardupilot/build
Autoconfiguration : enabled
Checking for program ‘python’ : /home/acharchalioti/anaconda3/bin/python
Checking for python version >= 3.6.9 : 3.11.7
Setting board to : sitl
Using toolchain : native
Checking for ‘g++’ (C++ compiler) : /usr/lib/ccache/g++
Checking for ‘gcc’ (C compiler) : /usr/lib/ccache/gcc
Checking for c flags ‘-MMD’ : yes
Checking for cxx flags ‘-MMD’ : yes
CXX Compiler : g++ 11.4.0
Checking for need to link with librt : not necessary
Checking for feenableexcept : yes
Enabling -Werror : yes
Enabled OpenDroneID : no
Enabled firmware ID checking : no
GPS Debug Logging : no
Enabled custom controller : yes
Checking for HAVE_CMATH_ISFINITE : yes
Checking for HAVE_CMATH_ISINF : yes
Checking for HAVE_CMATH_ISNAN : yes
Checking for NEED_CMATH_ISFINITE_STD_NAMESPACE : yes
Checking for NEED_CMATH_ISINF_STD_NAMESPACE : yes
Checking for NEED_CMATH_ISNAN_STD_NAMESPACE : yes
Checking for header endian.h : yes
Checking for header byteswap.h : yes
Checking for HAVE_MEMRCHR : yes
Configured VSCode Intellisense: : no
DC_DSDL compiler : /home/acharchalioti/sim_ws/src/ardupilot/modules/DroneCAN/dronecan_dsdlc/dronecan_dsdlc.py
Source is git repository : yes
Update submodules : yes
Checking for program ‘git’ : /usr/bin/git
Checking for program ‘size’ : /usr/bin/size
Benchmarks : disabled
Unit tests : enabled
Scripting : maybe
Scripting runtime checks : enabled
Debug build : disabled
Coverage build : disabled
Force 32-bit build : disabled
Checking for program ‘rsync’ : /usr/bin/rsync
‘configure’ finished successfully (1.050s)
{‘model’: ‘+’, ‘waf_target’: ‘bin/arducopter’, ‘default_params_filename’: ‘default_params/copter.parm’, ‘sitl-port’: True}
SIM_VEHICLE: Building
SIM_VEHICLE: “/home/acharchalioti/sim_ws/src/ardupilot/modules/waf/waf-light” “build” “–target” “bin/arducopter”
Waf: Entering directory /home/acharchalioti/sim_ws/src/ardupilot/build/sitl' Embedding file locations.txt:Tools/autotest/locations.txt Embedding file models/Callisto.json:Tools/autotest/models/Callisto.json Embedding file models/plane-3d.parm:Tools/autotest/models/plane-3d.parm Embedding file models/plane.parm:Tools/autotest/models/plane.parm Embedding file models/xplane_heli.json:Tools/autotest/models/xplane_heli.json Embedding file models/xplane_plane.json:Tools/autotest/models/xplane_plane.json Waf: Leaving directory
/home/acharchalioti/sim_ws/src/ardupilot/build/sitl’
BUILD SUMMARY
Build directory: /home/acharchalioti/sim_ws/src/ardupilot/build/sitl
Target Text (B) Data (B) BSS (B) Total Flash Used (B) Free Flash (B) External Flash Used (B)
bin/arducopter 4016316 183549 218696 4199865 Not Applicable Not Applicable
‘build’ finished successfully (1.436s)
SIM_VEHICLE: Using defaults from (src/ardupilot/Tools/autotest/default_params/copter.parm)
SIM_VEHICLE: Run ArduCopter
SIM_VEHICLE: “/home/acharchalioti/sim_ws/src/ardupilot/Tools/autotest/run_in_terminal_window.sh” “ArduCopter” “/home/acharchalioti/sim_ws/src/ardupilot/build/sitl/bin/arducopter” “-S” “–model” “+” “–speedup” “1” “–slave” “0” “–defaults” “src/ardupilot/Tools/autotest/default_params/copter.parm” “–sim-address=127.0.0.1” “-I0”
SIM_VEHICLE: Run MavProxy
SIM_VEHICLE: “mavproxy.py” “–out” “127.0.0.1:14550” “–master” “tcp:127.0.0.1:5760” “–sitl” “127.0.0.1:5501” “–map” “–console”
RiTW: Starting ArduCopter : /home/acharchalioti/sim_ws/src/ardupilot/build/sitl/bin/arducopter -S --model + --speedup 1 --slave 0 --defaults src/ardupilot/Tools/autotest/default_params/copter.parm --sim-address=127.0.0.1 -I0
Connect tcp:127.0.0.1:5760 source_system=255
Failed to load module: No module named ‘console’. Use ‘set moddebug 3’ in the MAVProxy console to enable traceback
Failed to load module: No module named ‘map’. Use ‘set moddebug 3’ in the MAVProxy console to enable traceback
Log Directory:
Telemetry log: mav.tlog
Waiting for heartbeat from tcp:127.0.0.1:5760
MAV> Detected vehicle 1:1 on link 0
online system 1
STABILIZE> Mode STABILIZE
AP: Barometer 1 calibration complete
AP: Barometer 2 calibration complete
Init Gyro**AP: ArduCopter V4.5.7 (f8d13d34)
AP: 78a8ba5a77ae4bc292acc7d503035e0a
AP: Frame: QUAD/PLUS
AP: ArduPilot Ready
AP: AHRS: DCM active
AP: RC7: SaveWaypoint LOW
Received 1390 parameters (ftp)
Saved 1390 parameters to mav.parm
AP: EKF3 IMU0 initialised
AP: EKF3 IMU1 initialised
AP: AHRS: EKF3 active
AP: EKF3 IMU1 tilt alignment complete
AP: EKF3 IMU0 tilt alignment complete
AP: EKF3 IMU1 MAG0 initial yaw alignment complete
AP: EKF3 IMU0 MAG0 initial yaw alignment complete
AP: GPS 1: detected as u-blox at 230400 baud
fence present
Flight battery 100 percent
MAV> AP: EKF3 IMU1 origin set
AP: Field Elevation Set: 584m
AP: EKF3 IMU0 origin set
AP: EKF3 IMU0 is using GPS
AP: EKF3 IMU1 is using GPS
2.
gz sim --version
Gazebo Sim, version 8.8.0
Copyright (C) 2018 Open Source Robotics Foundation.
Released under the Apache 2.0 License.
gz sim -v4 -r shapes.sdf
[Msg] Gazebo Sim GUI v8.8.0
[Dbg] [gz.cc:166] Subscribing to [/gazebo/starting_world].
[Dbg] [gz.cc:168] Waiting for a world to be set from the GUI...
[Dbg] [Gui.cc:275] Waiting for subscribers to [/gazebo/starting_world]...
[Msg] Received world [shapes.sdf] from the GUI.
[Dbg] [gz.cc:172] Unsubscribing from [/gazebo/starting_world].
[Msg] Gazebo Sim Server v8.8.0
[Msg] Loading SDF world file[/usr/share/gz/gz-sim8/worlds/shapes.sdf].
[Dbg] [Application.cc:96] Initializing application.
[Dbg] [Application.cc:170] Qt using OpenGL graphics interface
[GUI] [Dbg] [Application.cc:657] Create main window
[Msg] Serving entity system service on [/entity/system/add]
[Msg] Loaded level [default]
[Msg] No systems loaded from SDF, loading defaults
[Msg] Copied installed config [/usr/share/gz/gz-sim8/server.config] to default config [/home/acharchalioti/.gz/sim/8/server.config].
[Dbg] [ServerConfig.cc:1034] Loaded (3) plugins from file [/home/acharchalioti/.gz/sim/8/server.config]
[Dbg] [Physics.cc:871] Loaded [gz::physics::dartsim::Plugin] from library [/usr/lib/x86_64-linux-gnu/gz-physics-7/engine-plugins/libgz-physics-dartsim-plugin.so]
[Dbg] [SystemManager.cc:80] Loaded system [gz::sim::systems::Physics] for entity [1]
[Msg] Create service on [/world/shapes/create]
[Msg] Remove service on [/world/shapes/remove]
[Msg] Pose service on [/world/shapes/set_pose]
[Msg] Pose service on [/world/shapes/set_pose_vector]
[Msg] Light configuration service on [/world/shapes/light_config]
[Msg] Physics service on [/world/shapes/set_physics]
[Msg] SphericalCoordinates service on [/world/shapes/set_spherical_coordinates]
[Msg] Enable collision service on [/world/shapes/enable_collision]
[Msg] Disable collision service on [/world/shapes/disable_collision]
[Msg] Material service on [/world/shapes/visual_config]
[Msg] Material service on [/world/shapes/wheel_slip]
[Dbg] [SystemManager.cc:80] Loaded system [gz::sim::systems::UserCommands] for entity [1]
[Dbg] [SystemManager.cc:80] Loaded system [gz::sim::systems::SceneBroadcaster] for entity [1]
[Msg] Serving world controls on [/world/shapes/control], [/world/shapes/control/state] and [/world/shapes/playback/control]
[Msg] Serving GUI information on [/world/shapes/gui/info]
[Msg] World [shapes] initialized with [default_physics] physics profile.
[Msg] Serving world SDF generation service on [/world/shapes/generate_world_sdf]
[Msg] Serving world names on [/gazebo/worlds]
[Msg] Resource path add service on [/gazebo/resource_paths/add].
[Msg] Resource path get service on [/gazebo/resource_paths/get].
[Msg] Resource path resolve service on [/gazebo/resource_paths/resolve].
[Msg] Resource paths published on [/gazebo/resource_paths].
[Msg] Server control service on [/server_control].
[GUI] [Dbg] [PathManager.cc:68] Requesting resource paths through [/gazebo/resource_paths/get]
[GUI] [Dbg] [Gui.cc:355] GUI requesting list of world names. The server may be busy downloading resources. Please be patient.
[GUI] [Dbg] [PathManager.cc:57] Received resource paths.
[GUI] [Dbg] [Gui.cc:413] Requesting GUI from [/world/shapes/gui/info]...
[GUI] [Dbg] [GuiRunner.cc:149] Requesting initial state from [/world/shapes/state]...
[GUI] [Msg] Loading config [/home/acharchalioti/.gz/sim/8/gui.config]
[GUI] [Dbg] [Application.cc:528] Loading plugin [MinimalScene]
[GUI] [Dbg] [MinimalScene.cc:802] Creating gz-rendering interface for OpenGL
[GUI] [Dbg] [MinimalScene.cc:986] Creating render thread interface for OpenGL
[GUI] [Msg] Added plugin [3D View] to main window
[GUI] [Msg] Loaded plugin [MinimalScene] from path [/usr/lib/x86_64-linux-gnu/gz-gui-8/plugins/libMinimalScene.so]
[GUI] [Dbg] [Application.cc:528] Loading plugin [EntityContextMenuPlugin]
[GUI] [Msg] Currently tracking topic on [/gui/currently_tracked]
[GUI] [Wrn] [Application.cc:908] [QT] file::/EntityContextMenuPlugin/EntityContextMenuPlugin.qml:52:3: QML RenderWindowOverlay: Detected anchors on an item that is managed by a layout. This is undefined behavior; use Layout.alignment instead.
[GUI] [Wrn] [Application.cc:908] [QT] file::/EntityContextMenuPlugin/EntityContextMenuPlugin.qml:67:3: QML EntityContextMenu: Detected anchors on an item that is managed by a layout. This is undefined behavior; use Layout.alignment instead.
[GUI] [Msg] Added plugin [Entity Context Menu] to main window
[GUI] [Msg] Loaded plugin [EntityContextMenuPlugin] from path [/usr/lib/x86_64-linux-gnu/gz-sim-8/plugins/gui/libEntityContextMenuPlugin.so]
[GUI] [Dbg] [Application.cc:528] Loading plugin [GzSceneManager]
[GUI] [Msg] Added plugin [Scene Manager] to main window
[GUI] [Msg] Loaded plugin [GzSceneManager] from path [/usr/lib/x86_64-linux-gnu/gz-sim-8/plugins/gui/libGzSceneManager.so]
[GUI] [Dbg] [Application.cc:528] Loading plugin [InteractiveViewControl]
[GUI] [Msg] Camera view controller topic advertised on [/gui/camera/view_control]
[GUI] [Msg] Camera reference visual topic advertised on [/gui/camera/view_control/reference_visual]
[GUI] [Msg] Camera view control sensitivity advertised on [/gui/camera/view_control/sensitivity]
[GUI] [Msg] Added plugin [Interactive view control] to main window
[GUI] [Msg] Loaded plugin [InteractiveViewControl] from path [/usr/lib/x86_64-linux-gnu/gz-gui-8/plugins/libInteractiveViewControl.so]
[GUI] [Dbg] [Application.cc:528] Loading plugin [CameraTracking]
[GUI] [Msg] Added plugin [Camera tracking] to main window
[GUI] [Msg] Loaded plugin [CameraTracking] from path [/usr/lib/x86_64-linux-gnu/gz-gui-8/plugins/libCameraTracking.so]
[GUI] [Dbg] [Application.cc:528] Loading plugin [MarkerManager]
[GUI] [Msg] Listening to stats on [/world/shapes/stats]
[GUI] [Msg] Added plugin [Marker Manager] to main window
[GUI] [Msg] Loaded plugin [MarkerManager] from path [/usr/lib/x86_64-linux-gnu/gz-gui-8/plugins/libMarkerManager.so]
[GUI] [Dbg] [Application.cc:528] Loading plugin [SelectEntities]
[GUI] [Msg] Added plugin [Select entities] to main window
[GUI] [Msg] Loaded plugin [SelectEntities] from path [/usr/lib/x86_64-linux-gnu/gz-sim-8/plugins/gui/libSelectEntities.so]
[GUI] [Dbg] [Application.cc:528] Loading plugin [Spawn]
[GUI] [Msg] Added plugin [Spawn] to main window
[GUI] [Msg] Loaded plugin [Spawn] from path [/usr/lib/x86_64-linux-gnu/gz-sim-8/plugins/gui/libSpawn.so]
[GUI] [Dbg] [Application.cc:528] Loading plugin [VisualizationCapabilities]
[GUI] [Msg] View as transparent service on [/gui/view/transparent]
[GUI] [Msg] View as wireframes service on [/gui/view/wireframes]
[GUI] [Msg] View center of mass service on [/gui/view/com]
[GUI] [Msg] View inertia service on [/gui/view/inertia]
[GUI] [Msg] View collisions service on [/gui/view/collisions]
[GUI] [Msg] View joints service on [/gui/view/joints]
[GUI] [Msg] View frames service on [/gui/view/frames]
[GUI] [Msg] Added plugin [Visualization capabilities] to main window
[GUI] [Msg] Loaded plugin [VisualizationCapabilities] from path [/usr/lib/x86_64-linux-gnu/gz-sim-8/plugins/gui/libVisualizationCapabilities.so]
[GUI] [Dbg] [Application.cc:528] Loading plugin [WorldControl]
[GUI] [Msg] Using world control service [/world/shapes/control]
[GUI] [Dbg] [WorldControl.cc:237] Using an event to share WorldControl msgs with the server
[GUI] [Msg] Added plugin [World control] to main window
[GUI] [Msg] Loaded plugin [WorldControl] from path [/usr/lib/x86_64-linux-gnu/gz-gui-8/plugins/libWorldControl.so]
[GUI] [Dbg] [Application.cc:528] Loading plugin [WorldStats]
[GUI] [Msg] Added plugin [World stats] to main window
[GUI] [Msg] Loaded plugin [WorldStats] from path [/usr/lib/x86_64-linux-gnu/gz-gui-8/plugins/libWorldStats.so]
[GUI] [Dbg] [Application.cc:528] Loading plugin [Shapes]
[GUI] [Msg] Added plugin [Shapes] to main window
[GUI] [Msg] Loaded plugin [Shapes] from path [/usr/lib/x86_64-linux-gnu/gz-sim-8/plugins/gui/libShapes.so]
[GUI] [Dbg] [Application.cc:528] Loading plugin [Lights]
[GUI] [Msg] Added plugin [Lights] to main window
[GUI] [Msg] Loaded plugin [Lights] from path [/usr/lib/x86_64-linux-gnu/gz-sim-8/plugins/gui/libLights.so]
[GUI] [Dbg] [Application.cc:528] Loading plugin [TransformControl]
[GUI] [Msg] Added plugin [Transform control] to main window
[GUI] [Msg] Loaded plugin [TransformControl] from path [/usr/lib/x86_64-linux-gnu/gz-sim-8/plugins/gui/libTransformControl.so]
[GUI] [Dbg] [Application.cc:528] Loading plugin [Screenshot]
[GUI] [Msg] Screenshot service on [/gui/screenshot]
[GUI] [Msg] Added plugin [Screenshot] to main window
[GUI] [Msg] Loaded plugin [Screenshot] from path [/usr/lib/x86_64-linux-gnu/gz-gui-8/plugins/libScreenshot.so]
[GUI] [Dbg] [Application.cc:528] Loading plugin [CopyPaste]
[GUI] [Msg] Added plugin [Copy/Paste] to main window
[GUI] [Msg] Loaded plugin [CopyPaste] from path [/usr/lib/x86_64-linux-gnu/gz-sim-8/plugins/gui/libCopyPaste.so]
[GUI] [Dbg] [Application.cc:528] Loading plugin [ComponentInspector]
[GUI] [Msg] Added plugin [Component inspector] to main window
[GUI] [Msg] Loaded plugin [ComponentInspector] from path [/usr/lib/x86_64-linux-gnu/gz-sim-8/plugins/gui/libComponentInspector.so]
[GUI] [Dbg] [Application.cc:528] Loading plugin [EntityTree]
[GUI] [Wrn] [Application.cc:908] [QT] file::/EntityTree/EntityTree.qml:148:7: QML ToolButton: Detected anchors on an item that is managed by a layout. This is undefined behavior; use Layout.alignment instead.
[GUI] [Msg] Added plugin [Entity tree] to main window
[GUI] [Msg] Loaded plugin [EntityTree] from path [/usr/lib/x86_64-linux-gnu/gz-sim-8/plugins/gui/libEntityTree.so]
[GUI] [Dbg] [Application.cc:398] Loading window config
[GUI] [Msg] Using server control service [/server_control]
[GUI] [Dbg] [Application.cc:671] Applying config
[GUI] [Wrn] [Application.cc:908] [QT] file::/WorldStats/WorldStats.qml:53:3: QML RowLayout: Binding loop detected for property "x"
[GUI] [Msg] Loading plugin [gz-rendering-ogre2]
libEGL warning: egl: failed to create dri2 screen
[GUI] [Dbg] [MinimalScene.cc:749] Create scene [scene]
[GUI] [Dbg] [MinimalScene.cc:1037] Creating texture node render interface for OpenGL
[GUI] [Dbg] [TransformControl.cc:453] TransformControl plugin is using camera [scene::Camera(65527)]
[GUI] [Dbg] [Spawn.cc:308] Spawn plugin is using camera [scene::Camera(65527)]
[GUI] [Dbg] [SelectEntities.cc:452] SelectEntities plugin is using camera [scene::Camera(65527)]
[GUI] [Dbg] [MarkerManager.cc:169] Advertise /marker/list service.
[GUI] [Dbg] [MarkerManager.cc:179] Advertise /marker/list.
[GUI] [Dbg] [MarkerManager.cc:189] Advertise /marker_array.
[GUI] [Dbg] [CameraTracking.cc:205] CameraTrackingPrivate plugin is moving camera [scene::Camera(65527)]
[GUI] [Msg] Move to service on [/gui/move_to]
[GUI] [Msg] Follow service on [/gui/follow] (deprecated)
[GUI] [Msg] Tracking topic on [/gui/track]
[GUI] [Msg] Tracking status topic on [/gui/currently_tracked]
[GUI] [Msg] Move to pose service on [/gui/move_to/pose]
[GUI] [Msg] Camera pose topic advertised on [/gui/camera/pose]
[GUI] [Msg] Follow offset service on [/gui/follow/offset] (deprecated)
[GUI] [Dbg] [InteractiveViewControl.cc:176] InteractiveViewControl plugin is moving camera [scene::Camera(65527)]
[GUI] [Dbg] [EntityContextMenuPlugin.cc:79] Entity context menu plugin is using camera [scene::Camera(65527)]
[Msg] Found no publishers on /stats, adding root stats topic
[Msg] Found no publishers on /clock, adding root clock topic
[Dbg] [SimulationRunner.cc:533] Creating PostUpdate worker threads: 2
[Dbg] [SimulationRunner.cc:544] Creating postupdate worker thread (0)
[Wrn] [SDFFeatures.cc:365] DART: Ellipsoid is not a supported collision geomerty primitive, using generated mesh of an ellipsoid instead
[Wrn] [SDFFeatures.cc:350] DART: Cone is not a supported collision geomerty primitive, using generated mesh of a cone instead
[Msg] Serving scene information on [/world/shapes/scene/info]
[Msg] Serving graph information on [/world/shapes/scene/graph]
[Msg] Serving full state on [/world/shapes/state]
[Msg] Serving full state (async) on [/world/shapes/state_async]
[Msg] Publishing scene information on [/world/shapes/scene/info]
[Msg] Publishing entity deletions on [/world/shapes/scene/deletion]
[Msg] Publishing state changes on [/world/shapes/state]
[Msg] Publishing pose messages on [/world/shapes/pose/info]
[Msg] Publishing dynamic pose messages on [/world/shapes/dynamic_pose/info]
[Dbg] [EntityComponentManager.cc:1656] Updated state thread iterators: 16 threads processing around 3 entities each.
[Wrn] [Model.hh:69] Skipping serialization / deserialization for models with //pose/@relative_to attribute.
[Wrn] [Component.hh:144] Trying to serialize component with data type [N3sdf3v145WorldE], which doesn't have `operator<>`. Component will not be deserialized.
- And lastly both commands simultaneously,
gz sim -v4 -r iris_runway.sdf
[Msg] Received world [iris_runway.sdf] from the GUI.
[Msg] Loading SDF world file[/home/acharchalioti/sim_ws/install/ardupilot_gazebo/share/ardupilot_gazebo/worlds/iris_runway.sdf].
[Dbg] [Sensors.cc:697] Configuring Sensors system
[Dbg] [Sensors.cc:557] SensorsPrivate::Run
[Dbg] [SystemManager.cc:80] Loaded system [gz::sim::systems::Sensors] for entity [1]
[Dbg] [Sensors.cc:532] SensorsPrivate::RenderThread started
[Dbg] [Sensors.cc:337] Waiting for init
[Msg] Create service on [/world/iris_runway/create]
[Msg] Remove service on [/world/iris_runway/remove]
[Msg] Pose service on [/world/iris_runway/set_pose]
[Msg] Pose service on [/world/iris_runway/set_pose_vector]
[Msg] Light configuration service on [/world/iris_runway/light_config]
[Msg] Physics service on [/world/iris_runway/set_physics]
[Msg] SphericalCoordinates service on [/world/iris_runway/set_spherical_coordinates]
[Msg] Enable collision service on [/world/iris_runway/enable_collision]
[Msg] Disable collision service on [/world/iris_runway/disable_collision]
[Msg] Material service on [/world/iris_runway/visual_config]
[Msg] Material service on [/world/iris_runway/wheel_slip]
[Dbg] [SystemManager.cc:80] Loaded system [gz::sim::systems::Imu] for entity [1]
[Dbg] [SystemManager.cc:80] Loaded system [gz::sim::systems::NavSat] for entity [1]
[Dbg] [SystemManager.cc:80] Loaded system [gz::sim::systems::JointStatePublisher] for entity [15]
[Dbg] [SystemManager.cc:80] Loaded system [gz::sim::systems::LiftDrag] for entity [15]
[Msg] ApplyJointForce subscribing to Double messages on [/model/iris_with_gimbal/joint/iris_with_standoffs::rotor_0_joint/cmd_force]
[Dbg] [SystemManager.cc:80] Loaded system [gz::sim::systems::ApplyJointForce] for entity [15]
[Msg] ApplyJointForce subscribing to Double messages on [/model/iris_with_gimbal/joint/iris_with_standoffs::rotor_1_joint/cmd_force]
[Msg] ApplyJointForce subscribing to Double messages on [/model/iris_with_gimbal/joint/iris_with_standoffs::rotor_2_joint/cmd_force]
[Msg] ApplyJointForce subscribing to Double messages on [/model/iris_with_gimbal/joint/iris_with_standoffs::rotor_3_joint/cmd_force]
[Msg] [iris_with_gimbal] Advertising on /gimbal/cmd_roll.
[Msg] [iris_with_gimbal] Advertising on /gimbal/cmd_pitch.
[Msg] [iris_with_gimbal] Advertising on /gimbal/cmd_yaw.
[Dbg] [SystemManager.cc:80] Loaded system [ArduPilotPlugin] for entity [15]
[Msg] JointPositionController subscribing to Double messages on [/gimbal/cmd_roll]
[Dbg] [JointPositionController.cc:302] [JointPositionController] system parameters:
[Dbg] [JointPositionController.cc:303] p_gain: [2]
[Dbg] [JointPositionController.cc:304] i_gain: [0.1]
[Dbg] [JointPositionController.cc:305] d_gain: [0.01]
[Dbg] [JointPositionController.cc:306] i_max: [1]
[Dbg] [JointPositionController.cc:307] i_min: [-1]
[Dbg] [JointPositionController.cc:308] cmd_max: [1000]
[Dbg] [JointPositionController.cc:309] cmd_min: [-1000]
[Dbg] [JointPositionController.cc:310] cmd_offset: [0]
[Dbg] [JointPositionController.cc:311] Topic: [/gimbal/cmd_roll]
[Dbg] [JointPositionController.cc:312] initial_position: [0]
[Dbg] [SystemManager.cc:80] Loaded system [gz::sim::systems::JointPositionController] for entity [15]
[Msg] JointPositionController subscribing to Double messages on [/gimbal/cmd_pitch]
[Dbg] [JointPositionController.cc:311] Topic: [/gimbal/cmd_pitch]
[Msg] JointPositionController subscribing to Double messages on [/gimbal/cmd_yaw]
[Dbg] [JointPositionController.cc:311] Topic: [/gimbal/cmd_yaw]
[Dbg] [CameraZoomPlugin.cc:309] CameraZoomPlugin attached to sensor [camera].
[Dbg] [CameraZoomPlugin.cc:380] CameraZoomPlugin subscribing to messages on [/model/gimbal/sensor/camera/zoom/cmd_zoom]
[Dbg] [SystemManager.cc:80] Loaded system [CameraZoomPlugin] for entity [59]
Error while loading the library [/home/acharchalioti/sim_ws/install/ardupilot_gazebo/lib/ardupilot_gazebo/libGstCameraPlugin.so]: /home/acharchalioti/anaconda3/lib/libgobject-2.0.so.0: undefined symbol: g_string_free_and_steal
[Err] [SystemLoader.cc:107] Failed to load system plugin: (Reason: No plugins detected in library)
- Requested plugin name: [GstCameraPlugin]
- Requested library name: [GstCameraPlugin]
- Resolved library path: [/home/acharchalioti/sim_ws/install/ardupilot_gazebo/lib/ardupilot_gazebo/libGstCameraPlugin.so]
[Msg] Serving world controls on [/world/iris_runway/control], [/world/iris_runway/control/state] and [/world/iris_runway/playback/control]
[Msg] Serving GUI information on [/world/iris_runway/gui/info]
[Msg] World [iris_runway] initialized with [default_physics] physics profile.
[Msg] Serving world SDF generation service on [/world/iris_runway/generate_world_sdf]
[GUI] [Dbg] [Gui.cc:413] Requesting GUI from [/world/iris_runway/gui/info]...
[GUI] [Dbg] [GuiRunner.cc:149] Requesting initial state from [/world/iris_runway/state]...
[GUI] [Msg] Listening to stats on [/world/iris_runway/stats]
[GUI] [Msg] Using world control service [/world/iris_runway/control]
[Dbg] [SimulationRunner.cc:533] Creating PostUpdate worker threads: 8
[Dbg] [SimulationRunner.cc:544] Creating postupdate worker thread (1)
[Dbg] [SimulationRunner.cc:544] Creating postupdate worker thread (2)
[Dbg] [SimulationRunner.cc:544] Creating postupdate worker thread (3)
[Dbg] [SimulationRunner.cc:544] Creating postupdate worker thread (4)
[Dbg] [SimulationRunner.cc:544] Creating postupdate worker thread (5)
[Dbg] [SimulationRunner.cc:544] Creating postupdate worker thread (6)
[Msg] Found IMU sensor with name [iris_with_standoffs::imu_link::imu_sensor]
[Dbg] [ArduPilotPlugin.cc:1158] Computed IMU topic to be: world/iris_runway/model/iris_with_gimbal/model/iris_with_standoffs/link/imu_link/sensor/imu_sensor/imu
[Dbg] [JointPositionController.cc:376] Identified joint [gimbal::roll_joint] as Entity [61]
[Dbg] [JointPositionController.cc:376] Identified joint [gimbal::pitch_joint] as Entity [62]
[Dbg] [JointPositionController.cc:376] Identified joint [gimbal::yaw_joint] as Entity [60]
[Dbg] [SDFFeatures.cc:332] Mesh construction from an SDF has not been implemented yet for dartsim. Use AttachMeshShapeFeature to use mesh shapes.
[Dbg] [SDFFeatures.cc:864] The geometry element of collision [yaw_collision] couldn't be created
[Dbg] [SDFFeatures.cc:864] The geometry element of collision [roll_collision] couldn't be created
[Dbg] [SDFFeatures.cc:864] The geometry element of collision [pitch_collision] couldn't be created
Msg [NameManager::issueNewName] (Skeleton::BodyNode | iris_with_gimbal::iris_with_standoffs) The name [base_link] is a duplicate, so it has been renamed to [base_link(1)]
Msg [NameManager::issueNewName] (Skeleton::N4dart8dynamics9ShapeNodeE | iris_with_gimbal::iris_with_standoffs) The name [base_link:base_collision] is a duplicate, so it has been renamed to [base_link:base_collision(1)]
[Dbg] [Sensors.cc:953] Initialization needed
[Dbg] [Sensors.cc:349] Initializing render context
[Dbg] [CameraZoomPlugin.cc:502] Camera name: [iris_with_gimbal::gimbal::pitch_link::camera].
[Msg] Serving scene information on [/world/iris_runway/scene/info]
[Dbg] [ImuSensor.cc:150] [Msg] Serving graph information on [/world/iris_runway/scene/graph]
IMU data for [iris_with_gimbal::iris_with_standoffs::imu_link::imu_sensor] advertised on [world/iris_runway/model/iris_with_gimbal/model/iris_with_standoffs/link/imu_link/sensor/imu_sensor/imu]
[Msg] Serving full state on [/world/iris_runway/state]
[Msg] Serving full state (async) on [/world/iris_runway/state_async]
[Msg] Publishing scene information on [/world/iris_runway/scene/info]
[Msg] Publishing entity deletions on [/world/iris_runway/scene/deletion]
[Msg] Publishing state changes on [/world/iris_runway/state]
[Msg] Publishing pose messages on [/world/iris_runway/pose/info]
[Msg] Publishing dynamic pose messages on [/world/iris_runway/dynamic_pose/info]
[Dbg] [EntityComponentManager.cc:1656] Updated state thread iterators: 16 threads processing around 4 entities each.
[Wrn] [Model.hh:69] Skipping serialization / deserialization for models [Wrn] [Component.hh:144] Skipping serialization / deserialization for models with //pose/@relative_to attribute.
[Wrn] [Model.hh:69] Trying to serialize component with data type [N3sdf3v145WorldE[Wrn] [Model.hh:69] Skipping serialization / deserialization for models with //pose/@relative_to attribute.
with //pose/@relative_to attribute.`operator<>`. Component will not be deserialized.
[Dbg] [RenderUtil.cc:2643] Create scene [scene]
[Dbg] [RenderingIface.cc:156] No scene has been created yet
[Wrn] [CameraZoomPlugin.cc:218] No scene or camera sensors available.
[Wrn] [Component.hh:144] Trying to serialize component with data type [St6vectorIdSaIdEE], which doesn't have `operator<>`. Component will not be deserialized.
[Dbg] [CameraSensor.cc:398] Camera images for [iris_with_gimbal::gimbal::pitch_link::camera] advertised on [world/iris_runway/model/iris_with_gimbal/model/gimbal/link/pitch_link/sensor/camera/image]
[Dbg] [CameraSensor.cc:688] Camera info for [iris_with_gimbal::gimbal::pitch_link::camera] advertised on [/world/iris_runway/model/iris_with_gimbal/model/gimbal/link/pitch_link/sensor/camera/camera_info]
[Wrn] [Ogre2Camera.cc:421] Ogre2Camera::SetVisibilityMask: Mask bits c0000000 are set but will be ignored as they conflict with the reserved bits used internally by the ogre2 backend.
[Wrn] [ArduPilotPlugin.cc:1583] ArduPilot controller has reset
sim_vehicle.py -v ArduCopter -f gazebo-iris --model JSON --map --console
SIM_VEHICLE: Start
SIM_VEHICLE: "/home/acharchalioti/sim_ws/src/ardupilot/modules/waf/waf-light" "configure" "--board" "sitl"
Checking for program 'python' : /home/acharchalioti/anaconda3/bin/python
Checking for 'g++' (C++ compiler) : /usr/lib/ccache/g++
Checking for 'gcc' (C compiler) : /usr/lib/ccache/gcc
Checking for c flags '-MMD' : yes
Checking for cxx flags '-MMD' : yes
Checking for program 'git' : /usr/bin/git
Checking for program 'size' : /usr/bin/size
Scripting : maybe
Checking for program 'rsync' : /usr/bin/rsync
'configure' finished successfully (1.220s)
{'waf_target': 'bin/arducopter', 'default_params_filename': ['default_params/copter.parm', 'default_params/gazebo-iris.parm'], 'external': True, 'model': 'JSON', 'sitl-port': True}
SIM_VEHICLE: "/home/acharchalioti/sim_ws/src/ardupilot/modules/waf/waf-light" "build" "--target" "bin/arducopter"
Waf: Entering directory `/home/acharchalioti/sim_ws/src/ardupilot/build/sitl'
Waf: Leaving directory `/home/acharchalioti/sim_ws/src/ardupilot/build/sitl'
BUILD SUMMARY
'build' finished successfully (1.648s)
SIM_VEHICLE: Using defaults from (src/ardupilot/Tools/autotest/default_params/copter.parm,src/ardupilot/Tools/autotest/default_params/gazebo-iris.parm)
SIM_VEHICLE: "/home/acharchalioti/sim_ws/src/ardupilot/Tools/autotest/run_in_terminal_window.sh" "ArduCopter" "/home/acharchalioti/sim_ws/src/ardupilot/build/sitl/bin/arducopter" "-S" "--model" "JSON" "--speedup" "1" "--slave" "0" "--defaults" "src/ardupilot/Tools/autotest/default_params/copter.parm,src/ardupilot/Tools/autotest/default_params/gazebo-iris.parm" "--sim-address=127.0.0.1" "-I0"
SIM_VEHICLE: "mavproxy.py" "--out" "127.0.0.1:14550" "--master" "tcp:127.0.0.1:5760" "--sitl" "127.0.0.1:5501" "--map" "--console"
RiTW: Starting ArduCopter : /home/acharchalioti/sim_ws/src/ardupilot/build/sitl/bin/arducopter -S --model JSON --speedup 1 --slave 0 --defaults src/ardupilot/Tools/autotest/default_params/copter.parm,src/ardupilot/Tools/autotest/default_params/gazebo-iris.parm --sim-address=127.0.0.1 -I0
Failed to load module: No module named 'console'. Use 'set moddebug 3' in the MAVProxy console to enable traceback
Failed to load module: No module named 'map'. Use 'set moddebug 3' in the MAVProxy console to enable traceback
Log Directory:
online system 1
AP_IRLock_SITL::init()
AP: Calibrating barometer
AP: Frame: QUAD/X
Received 1424 parameters (ftp)
Saved 1424 parameters to mav.parm
AP: ArduPilot Ready
fence present
AP: RC8: PrecisionLoiter MIDDLE
Note, i know --map don’t work i will solve that.
Thank you in advance
