Ardupilot With Pixhawk 6C OSD on DJI Goggles
Hello everyone,
i have a question i am building a Drone with the pixhawk 6c it is going to be transmitting telemetry and control via the :
GX12 Dual-Band Gemini-X Radio Controller (M2) ELRS & XR4 Gemini Xrossband Dual-Band ExpressLRS Receiver.
i want to use the DJi o4 air unit pro and the Dji N3 goggles too for video transmission, but i havent found any clear info on OSD.
how does the pixhawk connect with the camera to transmit OSD with the feed, is it even possible with the O4 Unit?
if not what alternatives do you suggest considering that i am going to be relying heavily on mission planning since it is a VTOL with Alot of autopilot and Thermal Loitering etc.
i am also going to have a Rasberry pi 5 on board for image computing for search and rescue it will use simple machine learning/ Ai to analyze and find people on terrain and so on.
does this system need a seperate camera or is the video feed from the O4 air unit transmittable with any connection to the pi?
i simply need a long range method to transmitt good quality video with osd and at the same time have the felxibility of using a screen or a goggle - so a goggle with some kind of HDMI output would be great too.
Thank you all for your assistance (:slight_smile:
DJI air units behave all same regarding to OSD. No difference between original air unit or Caddx Vista (if these are enabled via ftp.wtf) and the new O4 air units. You will need a free UART on Pixhawk for connecting to the air unit.Google search will bring you to the right Ardupilot settings.
There is no way for accessing the air unit camera feed from a Raspberry pi, so you will need a second camera.
