I am trying out setting ardupilot parameters in SITL with mavproxy. I am setting parameter values for RC1_TRIM. I see that I can set floating values to the parameter though it is supposed to be an integer and also, I can use value that is out of range like 18000 though the range is between 800 to 2200.
Can anyone please explain if this is a bug or I am missing something?
MissionPlanner will warn you (and maybe QGC does too) but the checks for every parameter cannot be built into the firmware because of the available space.
