Hi everyone
When I try to do motor test nothing happen, motors don’t move and I don’t receive any fault message.
Any support will be appreciate.
Hi everyone
Maybe it is necessary to describe little more about your problem. Now one nows what you tried and what you have.
Have you assigned a frame type? It is important to move down the Mandatory Configs tab one-by-one, or just use the Ardupilot Methodic Configurator.
Also, yes it is important to provide a better description of your problem.
Yes, I selected frame type, my frame is an Octa-copter, co-axial configuration.
I checked the motors rotation now using throttle (low throttle) and all are working fine, when I try with mission planner motor test I get a message that say (the drone is no landed).
My second problem now is that the arming switch is not working, I can only arming using mission planner, arming switch assigned to CH5 and it respond in the control calibration window.
Ch5 by default is flight mode switch, you need to change the default flight mode switch, if not already done.
Also, depending on your firmware, there are 2 Arm/disarm options - before 4.2, after 4.2
Most likely you are using 4.6.x so just use after 4.2
fix arming and most likely the cause of motor test error that you are getting is related to being armed or in a weird flight mode, but needs to verified.
Also, can you share screenshot of the motor test tab
