Hi all,
I just installed HD Zero in one of my aircraft. I got my OSD and stick commands to work, but now I am faced with a new issue:
Is there a way disable stick commands (ie opening up the VTX and camera menus)?
My main issue is when I go to arm the aircraft (left stick down and right for a couple seconds), the RunCam camera menu opens (as it’s the same command). Ideally this would be solved on the HD Zero firmware side, but I am wondering if there is a work around in the meantime?
