ArduPilot EU Dev Call 2026-10-14
Attendees (unique): 5
UTC0809
Peter: Our get/set uBlox configuration from 2025 broke the v7 modules. Perhaps early v8 too.
  • I’ve pushed a simulation module in hopes to fix it.
UTC0811
Randy: Yes, nice to see that.
UTC0815
Peter: An “=” was missing on the failsafe throttle value check.
  • Makes it consistent across all vehicles.
Merged!
UTC0816
A patch to catch some waf misconfiguration causing failures.
Peter: Why don’t we have patches to QURT?
  • I can’t replicate the failure in the example.
Andrew: I can replicate it.
P: Ah yes, you’re right.
Merged!
UTC0823
A: I’d rather fix the underlying issue with the string operation.
  • Perhaps by adding a #pragma on the line that’s affected.
  • If this needs a specific optimizatoin level, how do we reproduce this in our workflow?
P: The AI says it reproduced it.
UTC0829
P: Let’s hear Hamish’s opinion, since it bends the spec a little bit.
UTC0831
P: Wait for Henry’s review to the fresh push.
UTC0832
A: Probably helps with other protocols, not just blheli.
P: LGTM
UTC0835
A: I’m thinking of having waf build ChibiOS, instead of cmake.
  • I’ll need some more time with this one.
UTC0838
P: I thought there was a move of the whoami(), not a duplication.
Merged!
UTC0840
A: I’ll wait for the AI review.
P: It is stale, asking for the change to go into master first.
A: Then this needs a rebase.
P: But I don’t see the duplicate whoami() here.
UTC0842
P: We should probably take optical flow off the 1M flash boards, it’s too much.
UTC0850
P: I think it’s wrong. The source select even isn’t more special than other, similar events that would potentially corrupt Replay.
A: I agree.
UTC0858
P: Needs testing.
UTC0902
Skipping it!
UTC0903
R: We had the winch clutch meaning backwards.
P: Needs some tidying up.
UTC0905
A: Pete wants to tackle this one.
UTC0906
End
