ArduPilot EU Dev Call 2026-08-19
Attendees (unique): 7
UTC0800
TECS severely overshoots the takeoff altitude in SITL.
George: 2 options
  • Use the airspeed control
  • Or I’ll go in and improve TECS
Peter: I’d prefer we fix this properly
Andrew: Reduce TKOFF_THR_MAX
  • TECS isn’t very good at takeoffs, we don’t want it to nose down when the airspeed is low.
UTC0814
A: Yes, I’m not opposed to that.
  • It will not end up in people’s boards anytime soon. People don’t upload their bootloaders frequently at all.
Merged!
UTC0819
A: I need a little more time to process this.
UTC0820
A: This sytem is very rare, in my opinion.
UTC0829
A: To what yaw measurement/baseline would the compass learning anchor to?
P: Not flying doesn’t mean the aircraft doesn’t move. A person might be carrying it around.
UTC0838
P: Bad things happen when you try to build more than one vehicle at once.
A: This used to work fine! That’s likely a regression.
P: ./waf all still works.
A: The appveyor script fails, but we can drop it, we don’t use it anymore.
  • The robot review points to legacy defines injecting the wrong thing at the wrong place. It’s likely not a problem with waf itself.
UTC0845
A: It would be nice to have a .sh script to configure the downloads (apart from the classic ardupilot invocations). It would allow us to test it locally more easilly.
  • Point your AI to the comments raised by my AI.
UTC0853
P: Looks OK, but we need to wait for the fix suggested.
UTC0856
https://github.com/ArduPilot/ardupilot/pull/mavlink/mavlink/2251
P: My concern is with the orientation field. The orientation changes.
A: You would have to use the v1 message.
P: The idea is to deprecate it. I suggest an extension to the v2 message, carrying the orientation quaoternion.
A: Do we have the orientation reported in another message, e.g. a camera or gimbal message?
P: Can’t find one.
A: Up to you whether to ask for the orientation field.
  • Would be nice to have an implementation in mind, in order to judge this.
P: Approved!
UTC0908
https://github.com/ArduPilot/ardupilot/pull/mavlink/rfcs/30
A: I’m not keen. An operator responding to a message is too slow. You would want Lua or a companion to react automatically, which is another route.
  • This looks very bespoke and not scalable.
  • These one-off messages are also costing flash onboard.
P: Maybe there is enough time in the system for an operator to react manually.
A: Perhaps. But the response mechanism/workflow is also missing from this suggestion.
UTC0922
MergeOnCIPass
UTC0924
P: Approved!
Merged!
UTC0926
A: This changes behaviour in RTL, it will ramp down eventually. There is risk of hitting trees and Pete is the one who should decide.
  • I see in the description that the previous behaviour was actually to step the altitude down immediately.
  • Pete has approved.
  • Some of the AI comments are valid, though.
  • Let’s have Pete check it again.
UTC0937
P: Approved!
Merged
UTC0940
A: Initially we computed it in every baro update. That was too expensive.
  • Then we updated if the baro alt changed by more than a threshold. But it caused step-effects in things like TECS.
  • Then we changed it again and cached it in AHRS.
  • Did we come full circle now?
  • No, we’re not recalculating every call. It’s updating with baro, which is around 50Hz.
  • Okay, this looks sensible.
Merged!
A: In the future, let’s make sure that a baro failure is handled.
UTC0950
P: The robot points at a problem with the config.
UTC0952
A: The AI comment re. not printing “USB connected” should be fixed.
P: It seems they are trying to modularize CubeNow into .inc files, then include them to this new board.
  • But it’s weird how they’re not modularizing the whole CubeNode.dat file.
UTC0959
A: There’s a serious bug found by AI re radian vs deg scaling.
UTC1008
P: The robot points to some serious bugs.
