ArduPilot EU Dev Call 2026-05-20
Attendees (unique): 10
UTC0700
Andrew: Hopefully this brings us closer to a further HAL abstraction.
  • We should have had promoted hwdef higher, so that we can have the same board with different HALs (ChibiOS, Zephyr, etc…).
  • You can already have one ethernet and ChibiOS network backend too, at the same time.
  • Next step is PPP with flow control.
Merged!
UTC0708
A: RemoteUARTDrover::write() could possibly lead to a hang if the threading is wrong?
  • Ah, no, that’s on the host side.
Peter: Found a case of uninitilized port use.
UTC0722
P: I’ll test this in the weekend.
UTC0723
P: We have a regression in Plane dead-reckoning in master.
A: Could it be that we are resetting isFlying on mode change?
P: Yes, isFlying is going to 0 in the autotest GuidedAttitudeNoGPS indeed. This is wrong.
George: Could it be that the dead-reckoning things we’re going too slow and flagging a not-flying condition?
A: It seems it’s moving fast enough at that point, but maybe it is a case of flying at a very low airspeed, below stall speed. So you’re not actually “flying” in the aerodynamic sense and should not use that assumption for fusion.
P: At the same time we’re at 0 throttle and we’re pitching up, losing a lot of airspeed.
A: Right. So we’re moving but because isFlying is false, we’re moving 0 velocity and this screws up the dead-reckoning.
  • We could use the “flies forward” flag of the EKF to block this code from executing.
  • It will work in Plane likely, but boats drifting at 0 throttle might indeed still get confused.
  • Randy, do boats handle dead-reckoning nicely? They don’t use the fly_forward flag.
Randy: I’ll check.
A: I just checked, it’s bad.
R: Okay, I’ll get on it.
P: Let’s merge AP_NavEKF3: do not look at takeoff for zero velocity fusion by andyp1per · Pull Request #33115 · ArduPilot/ardupilot · GitHub as a first mitigation.
A: And I’ll follow up.
R: Could we improve ‘isFlying’?
A: It’s hard, for example one holds a plane in the air against strong wind. Is it flying at this point?
R: We can probably gate the transition from not flying to flying and vice versa with different checks.
A: In planes it’s harder to tell if you landed than in planes, especially when you glide and almost hover. During a landing in headwind you might actually hover above the ground. We don’t want to think we’ve landed at 1m above the ground.
P: Okay, merging fix on CI pass.
UTC0803
A: Do we run unit tests for this kind of thing?
P: Yes, we do.
A: Approved!
UTC0810
P: How about this approach?
A: That’s also an okay approach. But let’s let Thomas decide what he wants.
UTC0815
A: You can declare a parameter structure in AP_SurfaceDistance, but instantiate them in Copter, then pass down the structre in the object constructor.
George: Ah, nice! I’ll try that.
P: The SITL knows to restart after the context is popped, if a reboot has been done in the test.
UTC0824
Khancyr’s idea and draft to find .Lua applets more easily.
P: I’m concerned that this will make it very hard to sunset some old Lua bindings.
R: How do users find and upload scripts now? Via Github?
Pierre: Yes.
G: Would it be possible to have the page connect to the autopilot, check versions and update?
P: Would it be possible to insert metadata on the script for the known-workig AP version? Then we could maybe issue a warning if you update AP firmware but keep the old script. And vice versa.
R: Very cool!
UTC0831
G: I’m happy with having the justification mandatory as well.
Merged!
UTC0836
P: Approved!
MergeOnCIPass
UTC0838
UTC0841
P: Since that’s a Holybro device and the PR is by a Holybro employee, then it’s okay to change the board hwdef.
UTC0846
P: We’ve got duplicate compass drivers!
  • jdahl added the duplicate and he’s now removing it.
UTC0847
P: Andy has raised objections.
UTC0848
Merged
UTC0850
A: I do have an F3 at hand!
  • Ah, this one doesn’t boot. I’ll try another one.
P: I have an F103 as well! I’ll try it too.
  • Hm… it doesn’t seem to accept the firmware.
A: Mine is works and is happy! Now let’s find a GPS to connect.
  • Works nicely.
UTC0906
P: This PR will detect the sticks moving and abort the overrides.
  • Let’s test the new changes again in Spring Valley.
