ArduPilot EU Dev Call 2025-11-26
Attendees (unique): 11
UTC000704
Sid Refactored to give more space in the DroneCAN array.
Merged!
Andrew Good to backport to 4.6, but via a beta that will get adequate testing.
UTC0710
A It’s unconditionally built, there are no ifdefs. But it’s not getting autodetected.
  • Would be nice to see a flight log, along with another IMU for comparison.
  • The clang build fails with errors.
Peter Are we okay with them claiming this IMU for their board?
A They provide reasonably good FC boards.
P ARK also provide support for this sensor, via a PR.
S Why do they integrate with an FPGA? The chip is SPI.
A Because it lacks a FIFO.
S There are data-ready pins, there are cheaper ways to do this.
UTC0721
A Okay, let’s approve this.
R I don’t think it’s such a popular option. It might be broken.
Merged!
UTC0723
Merged!
UTC0724
P It’s very similar to LIS3MDL, but I understand it’s hard to share code with OwnPtr.
Merged!
UTC0727
A hal_bootloader_build is probably a better alternative to declaring a static.
P Is AP_FILESYSTEM_FATFS_ENABLED true in bootloader? It shouldn’t be.
  • We probably need to explicitly disable it in the bootloader hwdef file.
A That will allow us to not use the static keyword.
Merged!
UTC0739
Matt Still a WIP.
P It would be nice to add an autotest or two.
M It’s a bit hard, because you need the motorboat frame in an autotest to show the bug.
R is_destination_valid may not be always true, can you double-check?
P You can use customize_sitl_commandline() to pass custom frames.
UTC0752
P Weirdly for CubeBlack we save almost 1kB!
A If a DroneCAN compass works still in CubeBlack, then let’s call it good.
UTC0758
A Let’s double-check that gdb debugging still works on ChibiOS.
  • Also, let’s fence the asserts behind debug builds.
UTC0800
P Keep in mind that sometimes SITL code runs also in FC boards when doing Sim On Hardware.
A An increasing frame_num doesn’t guarantee that we are in lockstep.
  • You can’t do actual lockstep against RealFlight.
  • Extrapolating that much (up to 100x) might not be a very good idea. Perhaps we need to account for the RF time jitter directly within EKF_TYPE 10.
  • Best to consult what we do for extrapolation in X-Plane.
  • We were also doing this as well for RealFlight in master, but this PR removes this call.
Andy Yes, the idea is to base the extrapolation based on the gyro timings.
  • Also, the extrapolation is not in the future, but in the past. We’re extrapolating to gradually reach the latest measurement.
A Are these micro-steps done in burst?
Andy Yes.
A In this case this will probably not work well in slow machines.
  • At least in my machine pausing in gdb works, and the EKF innovations are good!
  • Cygwin doesn’t seem to work, the control packets don’t seem to come through.
  • Unfortunately gdb doesn’t play nice with Cygwin.
UTC0839
P Leonard will probably want to review this.
Andy Actually he has! He suggested changes to the API.
UTC0853
P We’ll either have to stop introducing new compasses or drop old ones and their support. The space requirements are getting untenable.
Approved!
UTC0856
P Testing on harware is pending.
