ArduPilot EU Dev Call 2025-10-22
Attendees (unique): 11
UTC0702
Merged!
UTC0704
It looks good but it now has conflicts.
Peter rebased it.
MergeOnCIPass.
UTC0708
This needs a Copter maintainer to merge it.
UTC0709
Would be nice to have a separate error rate getter.
It’s a bit unclear what the error rate refers to. Not that this is PR is to blame for this.
UTC0716
Needs a Plane maintainer to merge it.
UTC0716
Would be nice for Randy to have a look.
UTC0718
Peter: This is a discontinuity in value behaviour, but it’s according to documentation.
George: I find this behaviour actually intuitive.
Merged!
UTC0721
We’d need Randy to pitch in.
UTC0722
Andy: Let’s make sure that we remember this change, when we back-port boards.
Peter: Left a note in the 4.6 Issues List.
Bumped for the next Dev Call.
UTC0732
Andy: I2C is quite slow, so when sharing DMA with the SD card, there’s the danger of failure to write in time.
  • But I’m okay with merging it, it’s specific to that vendor.
Merged!
UTC0734
We’ll need Sid to weigh in on this.
UTC0742
Andy: This is tested working.
Peter: Is the scale factor correct?
Andy: Haven’t checked.
  • I’ll make the changes then split this PR into two, one for the driver and one for the new board.
Peter: The PX4-2 connector description doesn’t match the silkscreen. Same for UART4.
  • The board_type ID is alrady taken.
  • Boards with 1M flash or less might not want this driver baked-in.
UTC0757
Amilcar: I can no longer access the parameter server, so I can’t test this anymore.
  • Perhaps my IP address changed and I can’t rsync in anymore.
  • This PR will allow GCSs (i.e. Mission Planner) to get the stable parameter .xml list, not the one from master.
  • I would like that we upload parameter descriptions for each patch release.
Peter: It would be nice if we uploaded them next to the board binaries.
Amilcar: I had suggested the same, but tridge wanted them in a separate, dedicated directory.
Peter: We could also be pointing the GCS to the correct parameter file in the manifest.json.
  • In any case, if you can set it up to push the parameter metadata next to the binaries, I’ll advocate for it.
  • I’ll go and refactor param_parse.py into a importable module.
