ArduPilot EU Dev Call 2025-10-15
Attendees (unique): 7
UTC0708
Peter: In general we don’t want to support fully generic AP_Periph builds.
Andrew: Andy, are you trying to save CPU with this change?
  • Let’s try to see if there’s an automatic method to detect whether there has been any valid output command. If not, then we can go with this PR.
    P: We’re probably going to have issues with NeoPixels.
UTC0719
A: SITL testing for this would be fine.
  • The test could fly a hard bank in FBWA, then get the trigger for this PR and check if nav roll and pitch have updeated.
UTC0725
Merged!
UTC0726
Andy: Scripting has only access to the lastly calculated check in the main code.
A: So we get a relative position as a result. But where is this relative to?
  • If we had access to the absolute position that this vector refers to, then this would be usable by the script to calculate the current location of the fence.
  • Why not return an absolute breach location?
Andy: Okay, I’ll adapt the API.
UTC0745
A: This feature depends on the define HAL_PROGRAM_SIZE_LIMIT_KB. If STRacing can’t get this feature, then that’s fine by me.
UTC0748
P: Question re. Math.h and Vector3.h.
  • They both have a (circular?) definition of is_zero() and could be untangled.
