ArduPilot EU Dev Call 2025-05-14
Attendees (unique): 7
UTC0708
Andrew: Using get_control_in_dz() would be more elegant.
  • It would save you a reboot as well.
Peter: I think I still need to set_range() on it.
UTC0714
A: It looks like it’s a bug in the TBS documentation, which we follow.
  • We had a user report that the Betaflight documentation is the correct source.
  • We need Andy to reply.
UTC0715
Randy: LGTM!
Merged!
UTC0719
A: I’d prefer it that the local node ID option is ticked by default in the “splash screen” where we select the interface.
  • But this approach here is OK as well.
  • Building this tool in Windows is hard. For Linux is pretty easy, utilizing python pip.
R: Giving access to the USB in WSL is a bit tricky as well.
UTC0726
Discussion on whether this tool could be used to capture and replay data from the LD90 lidar, which has a driver issue currently.
UTC0743
