Andrew Would be nice if the uint16 macros were replaced with the standard pointer macros.
Testing it on real hardware would be nice.
UTC0703
Peter Weirdly enough it costs a bit of flash to remove the unused variable.
Merged!
UTC0705
Merged!
UTC0706
Randy Approved. P The trim autotest seems to be flaking, I should fix it.
UTC0707
P Should make working with mission and fence items in the memory easier. A The msg reference argument wasn’t being used at all? P In one place only. A Again, weirdly, we remove arguments and the flash space occupance increases.
Perhaps you can have get_item return “invalid result”. Then the new item_exists() could be avoided. Perhaps.
UTC0717
Pto_str() returns an object which will not be destroyed, unless it was scoped. A Ah, OK. Nice to find out the reason.
Approved.
UTC0719
Sid I think Andy has approved. What’s pending is Andrew’s request on the IOMCU protocol.
I created a branch for that, which can become a PR once this one is merged.
A Some comments are not marked unresolved yet.
[ Discussion on the ./waf tricks required to trigger two different builds for CubeRed ]
[ Discussion that the secondary MCU on the CubeRed will act as IOMCU, not a fully secondary flight controller ]
P Why not implement the IOMCU protocol as a serial protocol, and flash a normal FCU firmware instead? S It’s kind of a weird protocol. We eventually want to have a PPP link between the two processors, and that’s where we want to get to. P Seems a bit unconventional to try to send IO expand commands, over a serial, encapsulated over a PPP. S The alternative is going to be a very bleeding edge protocol that we need to develop. A I’m concerned that the bootloader version checking is wrong, it might overwrite existign bootloaders. S Perhaps the version number is wrong. But the idea is to avoid re-flashing the same bootloader. A It would be nice to be able to discern if we’re trying to flash the old or the modern bootloader.
My principle concern is about breaking old boards.
A I’m surprized that the DMA changes were so small. That’s fortunate.
What testing has been done for SBUS and RCIN? And other functionality of teh IOMCU?
S I have checked with RCIN, flown with CubeRed. Did a size compare and IO firmware didn’t change size. A I checked too, and some IO firmwares did change size. Something like 8byts, so not large. Perhaps it’s best to do a binary comparison, not just the size.
But this is getting close.
UTC0751
Hasn’t been looked at in the last couple of weeks. We can’t progress this one today.
UTC0754
A Approved!
Demo of the static analyzer by Peter.
Discussion on one example issue in lua_bindings.cpp.
Discussion on a question of Henry’s, regarding a SITL plane getting locked in a QAssist situation.
Turns out it was a corner case, in conjunction with the fact that we limit the TECS pitch to ±3 deg during VTOL.
