Peter: Better log nan’s when DesPitch isn’t valid. Michelle: Can the log plotters cope? George: I can test. P: Also check what currently happens re. reinitialization now, with navpitch
UTC0715
Sid: Temperature shouldn’t be affected by imu rates. Andy: It was more a matter of consistency: we dont’ run fast imu on the initial temperature calibration.
RAM and CPU are not an immediate concern.
We can leave this for now, then.
UTC0720
A: I had baro issues with a Whoop, which I chased down to this driver. P: It would be nice if you had split the EXT_SENSOR change into another PR.
Could you test some more boards, if possible?
UTC0733
Sid: This issue can bring down the whole system, if the conditions align, and can’t be turned off before boot.
It could affect 4.6 and needs backport and affects default firmwares.
UTC0736
P: Could Michelle test it? M: I have to be away this week unfortunately. G: Could this be a side-effect of the ground-effect compensator? A: It does work a lot better in real flights. P: Okay, needs a confirmation by the code owners.
Besides some other review comments.
UTC0750
S: Fixing a logic level during boot could very well bring down other hardware, while fixing some.
It’s preferrable to add external pullup/down resistors where needed, per case.
It’s not easy to fix this via a user option
A: except for a custom build server build.
A new wiki page on servo connection good practices would be nice.
UTC0809
A: This is ready to go now. P: Needs rebase on master, can’t be done automatically. A: Done A: This feature is enabled by default on NAND-chip boards.
[Code review underway]
P: Why is there another JEDEC driver? We already have some. A: None of the existing drivers are factored enough to be usable, unfortunately. P: The filesystem driver shouldn’t be handling the SPI transfers. A: Agreed; We are doing the same in the other backends currently, though. P: We already test other JEDEC backends in SITL. We should be able to test LittleFS as well. A: Thomas mentioned he’d do the simulation after this feature is done.
[Discussion on logging throughput. Seems slower than regular SD, but the actual performance isn’t very clear. Mostly depends on our calling code overhead.]
[Discussion on binary size changes. Nothing too unexpected, but a couple of cases need to be looked at closer.]
UTC0909
P: Build failing because of binary space.
We’d better freeze what Pixhawk1-1M can support, at least in terms of compasses.
