Attendee count (max): 8
UTC0700 - Add AP_Periph support for Proximity sensors by rishabsingh3003 · Pull Request #21822 · ArduPilot/ardupilot · GitHub
- Some small fixups required
- Has been tested
- MergeOnCIPass
UTC0710 - Scripting: reduce memory needed for aerobatics by tridge · Pull Request #22327 · ArduPilot/ardupilot · GitHub
- Also together with 5.4.4
UTC0718 - Scripting: update lua to version 5.4.4 by tridge · Pull Request #22395 · ArduPilot/ardupilot · GitHub
- Cost 17k flash
- Might be able to regain through using -Os
- Tridge going to benchtest
UTC0728 - Make and use AP_LANDINGGEAR_ENABLED by peterbarker · Pull Request #21848 · ArduPilot/ardupilot · GitHub
- Some challenges over find the magic APM_Build_Type
- Merged!
UTC0730 - Copter: add weathervaneing by IamPete1 · Pull Request #21609 · ArduPilot/ardupilot · GitHub
- Copter: add weathervaning
- All good to go
UTC0731 - Correct gcs-channel-offset check by peterbarker · Pull Request #22399 · ArduPilot/ardupilot · GitHub
- Attempt to only modify off-by-one check in one place
- Needs some macro hackery to make editors happy
- Need to remove internal error
UTC0735 - GCS_MAVLink: Ensure serial tunnel avoids nullptr by stephendade · Pull Request #22397 · ArduPilot/ardupilot · GitHub
- Looks completely wrong to tridge …
- … but convinced himself it was right
- Doesn’t want an internal error for an intended use of the API
UTC0750 - In-flight FFT postfilter by andyp1per · Pull Request #21780 · ArduPilot/ardupilot · GitHub
- Lots of discussion around where the filters should get called and what the configuration should look like
- Andy to have a follow-up discussion with tridge
UTC0820 - Baro Z-axis wind estimate by andyp1per · Pull Request #22267 · ArduPilot/ardupilot · GitHub
UTC0821 - Plane: GCS_Mavlink: use base class DO_SET_HOME by IamPete1 · Pull Request #21978 · ArduPilot/ardupilot · GitHub
- Looks right
UTC0830 - Plane: tiltrotor: add throttle scaling for vectored yaw by IamPete1 · Pull Request #22376 · ArduPilot/ardupilot · GitHub
- Avoid wobble at pinned throttle
- Needs a fixup to scalaing
UTC0840 - Plane: move adjust_altitude_target functionality to per mode functions by IamPete1 · Pull Request #22380 · ArduPilot/ardupilot · GitHub
- Tridge wants the commits separated out
UTC0843 - Copter: Simulink Model and init scripts for Copter-4.3 by fbredeme · Pull Request #22354 · ArduPilot/ardupilot · GitHub
- MergeOnCIPass
