Attendee count (max): 8
UTC 0705 - hwdef: use minimal GPS driver (ublox only) on low flash boards by tridge · Pull Request #21997 · ArduPilot/ardupilot · GitHub
Take out all GPS drivers apart from UBLOX on 1Mb boards
Gains 19k flash
MergeOnCIPass
UTC0708 - Plane: added plane-3d frame by tridge · Pull Request #22000 · ArduPilot/ardupilot · GitHub
- Add plane 3d target for aerobatics scripting
- MergeOnCIPass
UTC0711 - GCS_MAVLink: prevent segv in ftp by tridge · Pull Request #21957 · ArduPilot/ardupilot · GitHub
Segv when calling ftp twice
MergeOnCIPass
UTC0713 - Copter: correct defines gating flowhold mode by peterbarker · Pull Request #21999 · ArduPilot/ardupilot · GitHub
Flowhold gating defines
MergeOnCIPass
UTC0714 - Use Float16_t in AP_Mission by tridge · Pull Request #21958 · ArduPilot/ardupilot · GitHub
- Convert mission items to Float16
- Some tidy ups required but generally meeting with approval
UTC0726 - move setting of MAV_SYS_STATUS_SENSOR_OPTICAL_FLOW sensors flags up by peterbarker · Pull Request #21998 · ArduPilot/ardupilot · GitHub
Optical flow restructure
MergeOnCIPass
UTC0727 - https://github.com/ArduPilot/ardupilot/pull/19732
Altitude in FBWB
MergeOnCIPass
UTC0729 - actions: only run single vehicle check for vehicle directory change by IamPete1 · Pull Request #21992 · ArduPilot/ardupilot · GitHub
- Improve CI times by only running vehicle specific tests
- Some more testing required but conceptually good
UTC0734 - CI: add Scripting docs check by IamPete1 · Pull Request #21965 · ArduPilot/ardupilot · GitHub
- Scripting docs check
- Merged!
UTC0735 - AP_Frsky_Telem: fixed roll and pitch for VTOL view by yaapu · Pull Request #21784 · ArduPilot/ardupilot · GitHub
- Fix roll pitch VTOL view (again!)
- Merged!
Also discussed:
