ArduPilot EU Dev Cal 2026-06-17
Attendees (unique): 6
UTC0704
Peter: This is preparation to let other estimators to have other (new) estimators to wind-triangle estimation.
Approved!
UTC0712
P: EKF1 was using DCM to initialize the filter. From 3 and forwards they bootstrap themselves. Apparently we wait for a couple of seconds to let the sensors warm up.
Merged!
UTC0716
Approved!
UTC0719
P: Similar to the one above.
UTC0721
Merged!
UTC0722
Andy: I think 8 channels will work, but it’s his board.
Andrew: Claude says compass orientation is wrong and baro masks are wrong.
Merged due to an itchy trigger finger.
UTC0727
A: Claude says there might be a buffer write overflow.
P: I’ll look at it again.
A: Should I start posting my LLM-generated reviews on the PRs?
Michelle: As long as it’s not very long and there aren’t lots of false postiives.
George: Given that some comments are on the noise margin, please make it clear that these review points aren’t all required to be addressed. I’m happy for it to be there as an advisory.
P: Please only for DevCallEU.
UTC0751
George: Fixed the recommendations.
P: Still has a few CI failures.
UTC0757
P: The LLM comment re. a DSHot firmware without a DSHot bootloader seems correct.
A: I think it’s a blocking bug.
UTC0803
Andy: You wouldn’t want this feature in all 2MB boards. It’s an additional 1500bytes.
  • But perhaps we can auto-enable it for boards that define the VTX protocol in a port.
P: We can probably do that, yes.
Andy: Shall we add it to the hwdef parser?
P: No, let’s avoid such magic and change all hwdef files.
UTC0819
Andy: We need Randy for this one.
P: We’ll test it in the weekend.
  • Please ensure that the new ground effect simulation is off by default. It can break other tests subtly.
UTC0833
Andy: I tried periodically resetting the baro offset in Copter and it doesn’t work nicely.
  • With the reset, learning of the accelerometer bias is far too slow.
A: I like periodically resetting to avoid the sudden alt. jump during arming.
P: I would also like it if we adopt the Plane behaviour and reset Home continuously while we are disarmed.
Andy: This PR has been open for far too long. If Randy agrees, I’d like to stop making changes here.
A: Please try plotbeta.ardupilot.org.
  • Ceasium is now asking for a lot of money to continue using Ceasium-Ion, so I removed it and rolled out a custom terrain DEM server.
