Ardupilot drone shaking, changed some notch settings, and drone is rotating around it self
how to know if i have telemetry data avilable to use that for gyro settings,
i disarmed the drone , because itis turning around.
For notch filter settings you mean?
Serial telemetry from the ESC to a serial port which you seem to have configured on serial 8
Bi-directional Dshot if the firmware supports it and your ESC provides it.
CAN ESC’s
But, no ESC telemetry is showing in the log. What flight controller is that and what ESC’s? And why using 4.7.0-dev firmware?
Then you have probably have the motor order or direction wrong. Use Mission Planner’s Motor test to confirm and fix it. Did you take the previously given advise to use the Methodic Configurator?
I did a first test with drone and this just arm , takeoff,land . Which was working okay but drone was shaking a lot when going up . So I had log file and started turning notch filter using dynamic fft. I changed those settings and did a test flight as soon as it is in air, drone was circling around . This was the log file I shared.
I have an blue jay esc, some h743 custom firmware which supports both px4 , ardupilot. I brought it from a company. It was originally with px4 but I wanted to flash ardupilot and start working with ardupilot. On bluejay ,I can see tx pin along with other s1-s4 pins ,source gnd. Now this is connected to my serial 8, I changed the protocol to esc telemetry and hoping that will log some data with esc telemetry. So that I can tune my notch with esc telemetry data .
Motor order and orientation can ruled out because it was already taking off once.
Regarding methodic configuratior ,I wanted to tune the drone by myself. So I didn’t use it .
When using ArduPilot methodic configurator you still need to tune the drone yourself and you will still learn how to tune it.
But it will force you to tune it correctly. And will allow you to learn faster
Ha, ha. Who’s to say it supports Bdshot? Did you get the firmware from them too? If it’s not in the Ardupilot repository it’s not officially supported.
Earlier when there was px4 on flight controller , I can see rpms of motors , I didn’t change anything related to escs . I only flashed fc with ardupilot
Now use AMC, it will teach you how to configure ArduPilot correctly
